Controlling Etched Foil Heaters - Electrical - DIY Chatroom Home Improvement Forum
Old 10-31-2012, 10:36 AM   #1
I am trying to control the temperature of several etched foil heaters that are currently just on a ON/OFF switch (using solid state relays). I have spoken to several individuals and just would like to get more advice. I was recommended to use a rheostat (light dimmer) or a variable transformer. I would like to control each plate separately. Each plate runs on 120 VAC at 600 W (5 A), there are 6 total plates. I think if I would use a rheostat is may burn out quickly, but if I use a variable transformer, would the heater function properly. Any advice/recommendations would be great. Thanks in advance.
luca131 is offline   Reply With Quote
Old 10-31-2012, 11:06 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
Use a line voltage thermostat.
Coastal South Carolina
Old 10-31-2012, 11:32 AM   #3
I do not think this will work. This heaters are encased in aluminum and will be immersed in water. The thermostat will be varying the heater temperature based on the ambient temperature ( I believe that's correct?).
I probably should have clarified it better, the heater temperature is not what I really what to be controlled but the power of the heaters.
Old 10-31-2012, 02:16 PM   #4
Semi-Pro Electro-Geek
Rewards Points: 2,892
You really want to control heater power, not temperature? That's easy. Just use a light dimmer rated for at least 600W. Lights and heaters have almost identical electrical characteristics. If you need more power than a light dimmer can handle, then use an "infinite control" from a stove. They work exactly the same way but are rated for higher current.
If you actually want to control temperature, you'll need a somewhat more sophisticated solution. A PID controller and solid state relay could keep your liquid temperature within 2 degrees of the setpoint for about $50 in parts.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is online now   Reply With Quote
Old 10-31-2012, 02:21 PM   #5
A "Handy Husband"
rjniles's Avatar
I guess you are trying to control the temperature of the water. Get a fish tank (aquarium) heater t-stat and use that to operate a control relay to the heaters.
Tags
heaters , rheostat , vac , variable transformer
Sub-panel for 3 space heaters Daneel Electrical 15 05-12-2011 10:08 AM
I have two water heaters with the pilot shutting off randomly stanlam Plumbing 3 08-14-2010 04:57 PM
Direct vent gas room heaters jmcw HVAC 1 06-02-2010 12:55 PM
how to wire up electrical baseboard heaters mmd21 Electrical 13 12-05-2008 09:11 AM
Tankless Water Heaters Recalled for Repair Due to Carbon Monoxide shimp Plumbing 1 01-22-2008 07:52 PM
