To Control Two Lights From Two Locations - Electrical - DIY Chatroom Home Improvement Forum
Old 04-05-2010, 10:29 PM   #1
To Control Two lights from Two locations
I need help with this wiring. My feed would be coming from the 2nd light box.
using 2 3-way switches.
Thanks to anyone that can help me
Enaido is offline   Reply With Quote
Old 04-06-2010, 02:00 AM   #2
You would wire it up the way you would a switch loop, except that you extend the switch loop by connecting two 3-way switches together using 14/3.
HooKooDooKu is offline   Reply With Quote
Old 04-06-2010, 06:52 AM   #3
Just call me Andrew
Rewards Points: 1,020
I think this is what you're trying to do:
Andrew
secutanudu is offline   Reply With Quote
Old 04-06-2010, 11:00 AM   #4
^ yes this is exactly what I'm trying to do instead the feed (power source is coming from the other light
Old 04-06-2010, 11:32 AM   #5
Just call me Andrew
Well just flip it around in your head then Wiring remains the same.
Andrew
Old 04-06-2010, 11:57 AM   #6
Rewards Points: 1,532
Pointing out little detail in the above multicolored diagram.
Common (black used in the example) coming back from the switch to the light fixture where power does not come in is connected to the light fixture black then and there.
Other common, coming back from the switch to the light fixture where power does come in, is connected to the power black.
Still, it is possible the box will be too crowded, particularly if it is round or octagonal instead of square. If the fixture has a dish like or conical cap (canopy) that fits against the ceiling or if the body of the fixture mounts on the ceiling with a pocket of empty space above, then you have more room for the wires.
Old 04-06-2010, 05:25 PM   #7
K thanks for the help guys
Old 04-06-2010, 09:31 PM   #8
" Euro " electrician
frenchelectrican's Avatar
Instead of using the XX-2 between the luminaire check out some big box store they may have XX-4 or XX-2-2 NM's if that the case it will be easier to do that so that way you will not get the XX-2's crisscrossed at all.
Merci,Marc
Finding underground electric wire for driveway lights. mitch21131 Electrical 25 09-24-2012 08:52 AM
Landscape lights BlueBSH Landscaping & Lawn Care 2 02-24-2010 09:43 PM
Wiring up an outside set of motion sensing lights airdaleairdale Electrical 1 06-11-2009 08:35 PM
Changing switch for lights in basement, confused on current wiring. RyanD Electrical 2 05-14-2009 08:37 PM
Adding can lights to an existing circuit TexasEd Electrical 1 06-17-2008 07:23 PM
