Control Top And Bottom Outlets Independently With Two Toggle Switches - Electrical - DIY Chatroom Home Improvement Forum
Old 05-29-2011, 05:42 AM   #1
Control top and bottom outlets independently with two toggle switches
I got a parts washer for free and I changed it from one switch and one outlet to two switches and two outlets. I followed the electric schematic to the t but its not working right. When I turn on one switch both outlets become live. Obviously I want one switch to control one outlet, and the other to control the other. Halp pls.
golfer2000 is offline   Reply With Quote
Old 05-29-2011, 07:06 AM   #2
Lic Elect/Inspector/CPO
The tab betwen the to hot terminal has to removed. This will let each outlet work serperatly
Additionally
The green wire from switch on right to outlet needs to be changed to a color other than green or white.
The ground needs to be attached to box
NJMarine is offline   Reply With Quote
Old 05-29-2011, 08:16 AM   #3
Licensed electrician
Rewards Points: 1,240
The white wire from the top switch should also be changed to black. The conventions on wire colors and purposes have not been followed.
Old 05-29-2011, 08:41 AM   #4
Missed that one Time for more coffee
Old 05-30-2011, 02:43 AM   #5
how does that look? It works great, thanks to everyone.
Old 05-30-2011, 03:40 PM   #6
Scared Electrician
Saturday Cowboy's Avatar
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Old 05-30-2011, 05:42 PM   #7
Mad Scientist
That's just excellent, right there. I love it when good advice is given, and followed.
Make sure to scrape/sand off the paint where the ground wire connects to the box, if you haven't already.
McSteve is offline   Reply With Quote
Old 05-30-2011, 07:19 PM   #8
I like the timely and accurate help here too! I did scrape off the paint, more so on the other side though. Probably not the right grounding screw, but Im pretty sure it gets the job done.
Old 05-30-2011, 07:49 PM   #9
Much nicer. Congrats.
Old 05-30-2011, 09:25 PM   #10
Thanks again
