Contradictions - Electrical - DIY Chatroom Home Improvement Forum
Old 06-13-2010, 10:10 AM   #1
the Musigician
DangerMouse's Avatar
Contradictions
OK, NOW I'm confused....
The PACKAGE says for bath and kitchen use, the INSPECTOR says I have to use them, but the DEVICE says........ WHAT????
DM
Old 06-13-2010, 10:20 AM   #2
I think the 1st pic is a hair dryer, almost looks like a drill
Ah....you mean the sticker...weird
Are they tamper resistant ?
Outside use must be weather resistant now
I think that is the reason for the sticker
Old 06-13-2010, 10:38 AM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
Bingo!
Speedy Petey is online now   Reply With Quote
Old 06-13-2010, 10:58 AM   #4
Mad Scientist
As soon as I have a little surplus cash, I think I'm going to tear apart a Leviton TR GFCI and WR GFCI. I believe them to be the exact same unit, with different markings and a different price...
McSteve is offline   Reply With Quote
Old 06-13-2010, 11:12 AM   #5
the Musigician
Oh.... well it was just stupid to me, baths and kitchens ARE wet and/or damp areas! LOL
Probably confuses a lot of people.... or at least one....
DM
Old 06-13-2010, 11:45 AM   #6
Ummm.....no. Not at all.
IN the shower/tub is a wet location, that's about it.
Old 06-13-2010, 11:46 AM   #7
Location, Wet. Installations underground or in concrete slabs or masonry in direct contact with the earth; in locations subject to saturation with water or other liquids, such as vehicle washing areas; and in unprotected locations exposed to weather.
Old 06-13-2010, 11:58 AM   #8
the Musigician
Well, you've never seen the kitchen after MY kids are done "doing dishes"... LOL
DM
Old 06-13-2010, 12:04 PM   #9
And if you're a hobbyist you can use one to sense small current differences to detect and troubleshoot ground faults, rather than buying Fluke's expensive meter made for this purpose.
It helps to get the numbers off the Integrated Circuit inside so you know which IC pin to monitor. Then you just disable the internal relay and you're ready to convert a few mA of differential current into a few volts that you can read on a DVM.
If it uses this IC
http://www.national.com/ds/LM/LM1851.pdf
you'd monitor pin 5 or pin 1 shown on Figure 2.
Or, bare bones, just remove the toroid transformer, slide it over a two conductor cable, load the winding down with a resistor and measure its very small voltage output.
Old 06-13-2010, 01:18 PM   #10
DM
Yeah, you may be right.
I know my bathroom floor is almost always a "wet location".
Old 06-13-2010, 01:59 PM   #11
I=E/R
a7ecorsair's Avatar
Ya, but if it plumbed with plastic pipe there isn't ground path
a7ecorsair is offline   Reply With Quote
