Old 08-13-2008, 09:09 AM   #16
Moderator
Termite's Avatar
Contractor workmanship issues
Originally Posted by chris75 View Post
That is completely unenforceable
Wonder why they put it in the code then (and not just the NEC)? It absolutely is enforceable in certain circumstances, as deemed necessary by the authority having jurisdiction.
Old 08-13-2008, 10:00 AM   #17
Man, if you wanted it to look like a rats nest you could have just done it yourself.
The reason to hire a pro is to get a pro job,
wjlundyjr is offline   Reply With Quote
Old 08-13-2008, 10:56 AM   #18
UAW SKILLED TRADES
Stubbie's Avatar
I'm sorta split decisioned on this because i have seen a heck of a lot worse. I can't tell but there may be some support violations on the cables and pvc conduit. Other than that I don't think 110.12 would be enforced on this job.
Old 08-13-2008, 06:28 PM   #19
Electrician
But who is going to actually judge that it is ugly or not? lets take this example, take the AHJ's wife and tell the man if shes ugly or not. Hopefully for your sake shes a knockout!
This is the exact reason its not enforceable...
chris75 is offline   Reply With Quote
Old 08-13-2008, 08:16 PM   #20
The work was done by the {Master electrician himself} He is a one man show. And yes There is do doubt about it I could have done 10 x the job. In our county home owners are not allowed to do there own work has to be a Master Electrician pull the permit. He even told me that a shop did not need GFI for the outlets. He argued with the inspector about a grounding rod outside the building.
kfen is offline   Reply With Quote
Old 08-13-2008, 09:20 PM   #21
Electrician
I know the job is ugly and was by no means defending the man, I was only pointing out the fact that its not a violation, I do feel for ya, he really should have went over his game plan with you before he started. and I think hes a little behind on his code knowledge.
Old 08-13-2008, 10:14 PM   #22
Believe that you may hand him a check, with a finished amount...with a statement that when cashed he is paid in full, also that the work is unacceptable and that you reserve the right to another professional inspection.
Do not know what the amount of your small claims court is, however, check the law...worth the 50-100 dollars to get direction from an attorney...
Meet on the worksite with Inspector, "The Electrician", yourself and a friend that would, seem to be an attorney... well versed in construction and trades...there are several out there...this is not a witch hunt just to listen and to explain concerns.
RhinoRod1945 is offline   Reply With Quote
Old 08-14-2008, 01:20 AM   #23
UAW SKILLED TRADES
Stubbie's Avatar
That is total BS. You would end up the one being sued if you pulled that game on someone. I have a huge dislike for little weasels that haven't got the *!*!s to be up front with someone. First the inspector hasn't got the time to play childish games after the fact or before the fact. The inspection would be over.. he ain't coming back to try and entrap someone with some stupid little game of someone playing attorney and misrepresenting a legal authority. In court the electricians attorney could show a thousand jobs worse than this that were passed by the local authority. Then he would tear your case apart with the little game you played on the electrician. My guess is that you would end up in slander suit for filing frivolous against the defendant.
A frivolous suit is one without any legal merit. In some cases, such an action might be brought in bad faith for the purpose of harrassing the defendant. In such a case, the individual bringing the frivolous suit might be liable for damages for Malicious Prosecution.
Old 08-14-2008, 09:46 AM   #24
Moderator
Termite's Avatar
Well stated.
Old 08-14-2008, 10:33 AM   #25
If your not happy, you should let the guy know.
What did he say, give him a chance to make it right.
If he says get bent, then I guess your outta luck.
Old 08-14-2008, 10:39 AM   #26
47_47's Avatar
My thoughts exactly. More people should grow a set and face problems head on.
What we've got here is... failure to communicate. Some men you just can't reach. So you get what we had here last week, which is the way he wants it... well, he gets it.
47_47 is offline   Reply With Quote
Old 08-14-2008, 06:44 PM   #27
I have told him more than once I was not happy with his work. I do not know how to be any more upfront.wjlundyjr he has told me to get bent and today he Threatened me.
Old 08-14-2008, 11:25 PM   #28
Define: threatened
I've delt with some chitty contractors, but depending on the stress you want to put yourself thru your options are limited, if he does half azz work you can't do much of anything, thats why you get references, pay for work completed and babysit..
But I would probably just pay and get rid of him, then make sure you tell everyone about it.(where I live all contractors have to be registered with the jurisdiction). They will cancel a trade persons registration if they get allot of complaints.
If the inspector fails your work, you'll still probably end up paying the guy, and then paying someone else to fix it.
Old 08-15-2008, 02:18 AM   #29
UAW SKILLED TRADES
Stubbie's Avatar
Kfen
My comments were not directed at you but the other guy... Rhinorod. I'm not defending this guy that did your electrical work. That work is sub standard and it would appear you have told him that in no uncertain words. You don't need to define threatened to me I've been around his type.
It seems back in the thread you said this master argued with the inspector over code compliancy? And they will not pass it if you refuse the work? After being threatened I do believe he would have a problem with me accepting that work or paying him. It sounds like the local electrical authority needs to have a few words with this fella. I would also let them know you will not accept the workmanship and see where they go with it.
If they don't pass it he will have to make the corrections to the workmanship. First you need to visit with the inspectors preferably the ahj and the inspector who did the rough check and I assume the final hasn't been called for yet. You have every legal right to refuse payment if this work will not pass inspection. The catch here is of course... will local codes enforce poor workmanship. I believe you said they would. If the electrician gets bent over it.. fire him.. and let him pursue the outcome. Remember your going to have the ahj for electrical inspections on your side. They don't lose outcomes like this that I have ever experienced.
Old 08-15-2008, 07:27 AM   #30
Electrical Contractor
In this day and time, if someone threatens you, you have to beleive that they are willing to follow up with that threat.
You need a police report on this asap!
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Briggs and Stratton Murray lawn mower issues golfer2b Landscaping & Lawn Care 3 08-01-2008 10:42 PM
Toilet refilling issues wedge22 Plumbing 1 07-27-2008 06:49 PM
AC/Thermostat issues rzgwong HVAC 2 06-22-2008 12:08 AM
Electrical issues with home inspection toolmaan Electrical 20 08-10-2007 06:52 PM
Issues with appliance plug hgiljr Electrical 1 03-17-2007 08:09 AM
