Continuity Tester - Electrical - DIY Chatroom Home Improvement Forum
Old 12-10-2008, 10:39 PM   #1
Rewards Points: 150
continuity tester
should i buy one of these?
drewhart is offline   Reply With Quote
Old 12-10-2008, 11:58 PM   #2
Electrical Contractor
kbsparky's Avatar
What do you want to do with it once purchased?
Old 12-11-2008, 07:53 AM   #3
Rewards Points: 852
Most DMM's will perform simple continuity testing, and a lot of other things as well.
Ultrarunner2017 is offline   Reply With Quote
Old 12-11-2008, 09:09 AM   #4
Rewards Points: 150
i dont know what they do. i have a voltage detector, what can a ct do that a vt cant?
Old 12-11-2008, 09:14 AM   #5
It can test for continuity.
http://home.howstuffworks.com/continuity-tester.htm
jerryh3 is offline   Reply With Quote
Old 12-11-2008, 10:25 AM   #6
Rewards Points: 852
When testing for continuity, you must be sure the circuit is NOT powered.
Old 12-11-2008, 01:09 PM   #7
My favorite continuity tester is a home made one from radio shack.
9V battery, the thing a 9v battery clips into, with 2 leads, a small 9v piezo speaker and 2 alligator clips w/leads. Put it all together and tape the speaker to the battery with elec tape.
It is cheap, it has alligator clips and it is loud enough to hear from another room.
I usually make a batch for Christmas gifts. Thanks for reminding me.
220/221 is offline   Reply With Quote
Old 12-11-2008, 01:14 PM   #8
DIYer
I think you mean piezo buzzer... if they try this with just a piezo speaker, nothing will happen.
Gigs is offline   Reply With Quote
Old 12-11-2008, 01:20 PM   #9
OK....piezo buzzer then...but it doen't buzz, it emits a high pitched tone. It's about 1" in diameter....the smaller, the better
Old 12-11-2008, 01:54 PM   #10
For household use, it is 120v in series with an incand. lamp (or in series with a radio, for audible indication).
Old 12-11-2008, 02:59 PM   #11
You can buy a combination continuity tester and tone generator at Home Depot. They come with a probe for picking up the tone.
The tester has a 3 way switch. In one position it sends out a tone. Center is off and the 3rd position is for continuity.
The idea is to find a cable using the tone and probe, then verify it by checking its continuity!
Mine cost less than $30 and I've been using for years.
Old 12-11-2008, 05:06 PM   #12
Open Ground Receptacle Slau108 Electrical 3 07-21-2008 11:31 AM
On one outlet my GFCI tester has all three lights lit. What does it mean? Deck Electrical 6 07-09-2008 10:18 PM
Clamp on Amp Tester Help stagger19 Electrical 3 03-07-2007 09:26 PM
Electrical continuity Tool Rze Electrical 11 10-01-2006 05:10 PM
Circuit continuity Unregistered Electrical 9 11-28-2004 12:20 AM
