Continuing A Bedroom Single Pole Switch/light To A Closet Single Pole Switch/light - Electrical - DIY Chatroom Home Improvement Forum
Old 06-09-2013, 09:30 AM   #1
Continuing a bedroom single pole switch/light to a closet single pole switch/light
Hey everyone,
I am doing some wiring in an attic/room conversion. I am running wire into a single pole switch to control the bedroom lights. I would like to continue the run off of the light to another single pole switch that controls a closet light. I have included a wiring diagram from a book that shows a scenario of adding a receptacle to the end of a single pole switch/light run. Can I substitute the receptacle in this picture for another single pole switch/light?
Continuing a bedroom single pole switch/light to a closet single pole switch/light-lighting.jpg
chadsunderman is offline   Reply With Quote
Old 06-09-2013, 09:35 AM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Yes and no. You can continue the circuit to the closet switch, however, you cannot wire a switch like a receptacle.
Be aware, there are strict codes on what type of fixture can be placed how close to anything flammable in a clothes closet.
Old 06-09-2013, 09:41 AM   #3
Thanks for the quick response. So instead of the receptacle, I could put in a switch (using the ground and hot wire), connect the neutral wire to the neutral wire going to the light?
Old 06-09-2013, 10:29 AM   #4
Rewards Points: 2,516
Yes you can. I didnt show the ground going to the switch but you get the idea
hammerlane is offline   Reply With Quote
Single Pole vs. Double Pole Thermostat dforeid Electrical 14 08-26-2012 08:12 AM
Changing A Double Switch to a single pole switch and a dimmer switch loydbrahn Electrical 0 11-08-2011 11:00 PM
Double pole breaker used as single pole WonderingOne Electrical 11 11-30-2010 12:37 AM
single gang single pole switch on fan fabian Electrical 14 03-05-2009 01:11 AM
Wiring a single pole switch into a 220v circuit rlmorgan Electrical 38 10-15-2008 07:59 PM
