Constant And Switched Split Duplex Receptacle With 12-4 Cable - Electrical - DIY Chatroom Home Improvement Forum
Old 04-03-2014, 05:23 PM   #1
Rewards Points: 83
Constant and Switched Split duplex receptacle with 12-4 cable
Can I use 12/4 to wire 2 gang receptacle boxes with one constant hot receptacle, then break off the tab on the other receptacle in the same box and switch the top and bottom receptacle with two separate switches (A single pole and a 3-way). Here is the wire diagram that I am using and the example of what I want to do with the two gang box. I would pigtail off the hot in switchbox B to get the constant power to the constant hot receptacle and the 12-4 would replace the 12-3. Any problems with this?
Constant and Switched Split duplex receptacle with 12-4 cable-12-4-switched-constant-receptacles.jpg
pex006 is offline   Reply With Quote
Possible to wire constant outlet from switched outlet? MikesHouse Electrical 11 11-12-2012 11:14 AM
New outlets don't work!! SectumSempra Electrical 30 01-17-2011 11:34 PM
How to make a full switch recepticle half switched and half constant power? johncdbass Electrical 8 11-15-2010 01:19 PM
changing a switched receptacle to a ceiling fan travisc Electrical 1 06-08-2010 11:53 PM
Wiring for switched, split power outlets ELurie Electrical 9 06-21-2007 08:12 PM
