Consolidate 200Amp Panel - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-04-2011, 05:40 PM   #16
Ok...went to price 6/3 UF wire today. 3.64/ft. @ electric supply store. Also saw 2/2/2/4 Aluminum wire today at Home depot for 1.49/ft. It was Cerro wire Type SE. Can this be used in buried coduit? If not what rating and size aluminum wire do I need for a 100ft run? Looks like ita alot cheaper to use aluminum.....
kjr6306 is offline   Reply With Quote
Old 08-04-2011, 07:13 PM   #17
Sparky
Rewards Points: 510
if you're running pvc/conduit the whole way you dont need to use a cable assembly.
THHW or XHHW wire would be acceptable 3 #6 copper for Hots and neutral 1 # 10 Green Ground, or 3 #4 Aluminum for hots and neutral 1 #8 Green Ground
Techy is offline   Reply With Quote
Old 08-04-2011, 07:21 PM   #18
Yes I am using 2.5 inch gray pvc the entire length. What is the most cost effective wire to purchase? Would like to go a little on the larger size wire in case I need more later. Thinking about a pool in the future that I would run off this sub panel in the detached garage. That reminds me of another question. How many subpanels are you allowed to run off your main panel?
Old 08-04-2011, 07:32 PM   #19
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Aluminum XHHW is probably the most cost effective. #6 and smaller neutral has to be white the entire length. No limit on the number of sub panels.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
sub panel ground and neutral daddyrabbit Electrical 3 01-29-2010 07:49 AM
Moving several circuits to sub panel WoodworkerDave Electrical 2 09-27-2008 03:05 PM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 04:03 PM
Panel Placement In Outbuilding smitty286 Electrical 3 03-31-2008 01:20 PM
turn main panel into a sub panel? tikicarver Electrical 2 01-24-2008 08:37 AM
