Conservatory Cavity Walls - Electrical - DIY Chatroom Home Improvement Forum
Old 06-19-2007, 03:44 PM   #1
Hi All
I have spent a few days looking for information on putting cabling (for sockets) inside the cavity of the wall of a conservatory, but seem to have found conflicting information.
Is it ok to put cabling in a cavity wall of a conservatory?
If so are there any conditions e.g. does it have to be in conduit or fixed to the internal wall etc?
If not is there any neat way of hiding the cables ? we would like the walls inside left as brick.
Thanks in advance
Mike
mike347 is offline   Reply With Quote
Old 06-19-2007, 04:53 PM   #2
Master Electrician
JohnJ0906's Avatar
Need some more info.
What exactly is this conservatory?
What are the walls constructed of?
Could you describe the situation a little better?
John from Baltimore
One Day at a Time
"Experience is what you get when you were expecting something else"
"The bitterness of low quality lingers long after the sweetness of low cost is forgotten"
JohnJ0906 is offline   Reply With Quote
Old 06-20-2007, 04:36 AM   #3
Sure, Sorry should have said i'm in the UK too i guess.
It's about 3m by 4m attached to the house.
The 3 walls are made up of an inner and outer wall of brick with a 75mm cavity. The walls are about 600mm above damp proof / floor level, the rest up is UPVC frame and glass.
Thanks again
Mike
FINISHING BASEMENT WALLS - Cinder Block Walls tmacwith Building & Construction 4 12-06-2012 09:26 AM
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 09:50 PM
bowing walls - repair? elementx440 Building & Construction 26 03-04-2009 04:07 PM
Adding a room, footings for all walls, or just new exterior? mt232 Building & Construction 2 09-25-2006 07:55 PM
painting a room w/ both drywall and plaster walls J187 Painting 7 06-19-2006 06:33 PM
