Connection Inside Fluorescent T8 Wrap - Electrical - DIY Chatroom Home Improvement Forum
Old 07-22-2012, 06:55 AM   #1
Connection inside fluorescent t8 wrap
Hello!
Long time reader. First time poster.
I have not been able to find a clear answer to this, so hopefully someone here can help me.
I have an unfinished space that has only been framed. No plans to finish it further. I mounted a fluorescent t8 wrap fixture vertically to one of the studs.
I brought power to the switch, then went to the light.
Is it code to make the connection inside the fixture? It is a covered fixture, wires are rated to 90C.
Please find attached some pics showing fixture closed, fixture open, and the connection in question.
zubor is offline   Reply With Quote
Old 07-22-2012, 07:22 AM   #2
Licensed electrician
Rewards Points: 1,478
Connections are typically made inside the fixture. Someone removed the knockout for when the fixture is mounted over a junction box. This needs to be closed off and the smaller 1/2" knockout used a proper cable connector.
Old 07-22-2012, 07:31 AM   #3
Thanks Jim.
Got it. So the issue is not with the connection in the fixture, but rather how the cable enters.
There are no 1/2" knockouts
Old 07-22-2012, 07:57 AM   #4
joed's Avatar
Rewards Points: 12,388
That fixture is rated as a junction box so you are permitted to make connections inside it. The cable must be clamped as it enters the box and any old holes closed up.
Old 07-22-2012, 08:03 AM   #5
A 7/8" hole saw will make the proper size hole for a 1/2" NM connector.
It also looks like the cable needs to be secured within 12" of the fixture.
Wrap or Mirror Inside Corner Tile? Dsaj Kitchen & Bath Remodeling 0 06-06-2012 10:52 AM
gas dryer connection question rvegab00 Plumbing 7 12-07-2009 10:53 AM
Telephone Jack Connection Problem jogan Electrical 9 04-20-2009 06:10 AM
sealing INSIDE an exterior wall penatration measure thrice Electrical 1 01-24-2009 02:12 PM
No House Wrap On New House JoeZ430 Building & Construction 34 11-29-2007 10:51 AM
