-   -   Connection inside fluorescent t8 wrap (http://www.diychatroom.com/f18/connection-inside-fluorescent-t8-wrap-151121/)
zubor 07-22-2012 06:55 AM
3 Attachment(s)
Hello!
Long time reader. First time poster.
I have not been able to find a clear answer to this, so hopefully someone here can help me.
I have an unfinished space that has only been framed. No plans to finish it further. I mounted a fluorescent t8 wrap fixture vertically to one of the studs.
I brought power to the switch, then went to the light.
Is it code to make the connection inside the fixture? It is a covered fixture, wires are rated to 90C.
Please find attached some pics showing fixture closed, fixture open, and the connection in question.
Jim Port 07-22-2012 07:22 AM
Connections are typically made inside the fixture. Someone removed the knockout for when the fixture is mounted over a junction box. This needs to be closed off and the smaller 1/2" knockout used a proper cable connector.
zubor 07-22-2012 07:31 AM
Thanks Jim.
Got it. So the issue is not with the connection in the fixture, but rather how the cable enters.
There are no 1/2" knockouts :(
joed 07-22-2012 07:57 AM
That fixture is rated as a junction box so you are permitted to make connections inside it. The cable must be clamped as it enters the box and any old holes closed up.
Jim Port 07-22-2012 08:03 AM
A 7/8" hole saw will make the proper size hole for a 1/2" NM connector.
It also looks like the cable needs to be secured within 12" of the fixture.
