Old 01-27-2009, 07:16 AM   #16
Electrical Contractor
Connecting a Sub Panel
Originally Posted by Stubbie View Post
It's 5 below zero and your dog is barking at the back door and your wife is yelling and cussing at you to let her in at the front door.....Who do you let in??
The Dog. He will shut up once he is in the house!
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 01-27-2009, 07:27 AM   #17
Electrician
SD515's Avatar
...Test the lugs to ground for peace of mind. I don't care how you do it. Grab a rabbit put him on a dry wood stick and short the critter.. See if he smokes if he does power has not been removed and you just made dinner...
LAMO...Wrap the bunny in tin foil with carrots and potatos and make a stew...
Kyle
Old 01-27-2009, 08:32 AM   #18
Originally Posted by mntnvew View Post
excellent, then I will call them tomorrow. I aint about to fry my own ass
You may need a permit and have it inspected before the power company will hook you back up.
Gary
Gary_602z is offline   Reply With Quote
Old 01-27-2009, 09:06 AM   #19
DIY'er
jamiedolan's Avatar
I'm with Chris I don't understand what your doing? If your connecting to the feed thru lugs....just turn the main breaker in the panel off.
Just my experience on this,,, On my old pushmatic panel, the feed through lugs are directly above the unfused conductors. So you have to work within 1/2" -1" of the unfused conductors. Maybe his panel is different...
Jamie
Jamie Dolan - Neenah, WI
Need Help Uploading Photos?
jamiedolan is offline   Reply With Quote
Old 01-27-2009, 01:55 PM   #20
UAW SKILLED TRADES
Stubbie's Avatar
His is different. I believe he is in a Square d 200 amp combination meter/main and is feeding thru to a 200 amp panel inside his pole barn.
It should be like this on any modern residential panel I've seen. His meter/main is a brand new one.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 01-27-2009, 01:59 PM   #21
Stubbie is absolutely right. I used that exact diagram as a model.
So... Can I turn off main and kill feed thru lugs? Or should I call pwr company to come disconnect me for a few?
Thanks again!
mntnvew is offline   Reply With Quote
Old 01-27-2009, 02:13 PM   #22
Electrician
SD515's Avatar
As per Stubbie's picture, yes. But it's always best to double check with a voltmeter afterwards.
Kyle
Old 01-27-2009, 02:13 PM   #23
UAW SKILLED TRADES
Stubbie's Avatar
Hi
Yeah but I think after reviewing your earlier post the meter/main panel was a Siemens.
So you need to locate the main breaker and turn it off.
If the meter/main panel... main breaker is set up like the diagram. Turning the main off kills all power to the feed thru lugs but ya gotta check...cause we aint there to look at what you have...unless you can post a picture.
Stubbie
Old 01-27-2009, 02:44 PM   #24
DIY'er
jamiedolan's Avatar
Get a basic solenoid tester like this one to verify the power is off: (test on a live outlet first to make sure it functions)
http://www.homedepot.com/webapp/wcs/...ctId=100341461
Jamie
Old 01-27-2009, 02:50 PM   #25
Attachment 7706
Jamie
I have that model, thanks!
Old 01-27-2009, 03:15 PM   #26
Electrician
Originally Posted by philS View Post
Not only do you need to torque the big stuff properly, you need to retorque it after letting it sit for a few hours.
Bad advice, you NEVER re-torque.
chris75 is offline   Reply With Quote
Old 01-27-2009, 03:24 PM   #27
I was wondering if this was sound advice or not as the pwr company guys that ran the line under ground from the transformer for the new 200 AMP service only tightened it down once and then left.
Old House Rewire finnimus Electrical 15 05-13-2011 11:39 PM
Adding a second Electric sub panel TW Lucas Electrical 9 10-05-2008 03:37 AM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 11:27 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 04:03 PM
Connecting subpanel to main panel rtyui2 Electrical 10 12-07-2007 07:29 PM
