Connecting Series Of Lights - Electrical - DIY Chatroom Home Improvement Forum
Old 08-19-2008, 03:03 PM   #1
Connecting series of lights
I have a group of ground posts installed for line voltage ground lights. The UF cable is continuous. It loops into a post, goes underground, and loops to the next post.
To install the floods at the posts, is it best to cut the loop and end up with 2 sets of wires, or is it best to strip the loop in the middle only and attach the flood at the stripped point?
As you all know, dealing with stripping UF is no picnic.
rockee is offline   Reply With Quote
Old 08-19-2008, 04:25 PM   #2
Electrician
You need to cut and then splice the two ends together, and UF is pretty easy once you get the hang of it.
chris75 is offline   Reply With Quote
Old 08-19-2008, 04:56 PM   #3
Thanks for your reply. I'm getting used to stripping the UF - it takes practice.
Why is cutting the UF and splicing preferable to stripping in center and not cutting better connection?
Wires will be inside a small landscape ground post with threaded hole for insertion of male nipple of flood. What I have been doing is coating thread with teflon tape and then connecting with wire nuts, then wrapping all wire nuts in black tape, and placing screwing cap into post. I haven't been using the gell-filled wire nuts, since I was told by post manufacturer not needed. Do you agree?
Old 08-19-2008, 05:11 PM   #4
Electrician
What you describe sounds like a real PITA. I cant give a code violation, but I know its a whole lot of extra work on your part.
No special wire nuts needed, and dont use electrical tape on wire nuts, its so DIY.
Old 08-19-2008, 05:23 PM   #5
OK - but I actually was told by post manufacturer that to be sure, I should wrap the nuts with tape - I actually wrapped the whole bundle of 3 nuts - neatly - thought it would add extra protection. I have quite a few more to do, so if you say I don't need the tape, I will discontinue using it.
Old 08-19-2008, 05:38 PM   #6
Electrician
if the wirenuts don't stay on by themselves, then you did something wrong. Just try not to have the wirenuts upside down, this way any moisture will not accumulate inside and sit.
Old 08-19-2008, 05:51 PM   #7
Yes, I have 3 sizes of wire nuts, and am very precise about using correct ones and making sure they are tight. Since these posts are plastic, I put all ground wires (from leads and lamp) together with a wire nut, since I assumed not necessary to secure to the plastic post. The lamps i already installed were at end of runs so i didn't need to make decision of cutting the loops. Now I will cut loops for remaining ones.
What you just said about not having wire nuts upside down makes so much sense. Thanks for pointing it out.
undercabinet puck lights ccalmonte Electrical 7 08-05-2008 08:25 PM
Installing motion / security lights west-phoenix-az Electrical 2 07-11-2008 07:33 PM
Adding can lights to an existing circuit TexasEd Electrical 1 06-17-2008 07:23 PM
Added can lights, tripping GFI tandyt Electrical 3 05-18-2008 09:55 AM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 08:23 PM
