Connecting Romex - Electrical - DIY Chatroom Home Improvement Forum
Old 05-25-2010, 10:18 AM   #1
Connecting Romex
I am replacing my range hood and have discovered that the electrical cutouts on the old one seem to be on the opposite side of what is now standard. It was suggested to me in this thread that I should run the electrical wire up through the cabinet into a junction box and then run a new wire to the opposite side:
Range hood installation problem
I think this is what I'm going to do since it will make it easier to replace the range hood in the future should the new one ever need to be replaced.
Now my question...
I'm not sure what type of cable I have currently sticking out of the wall. It is a white cable with a white, black , and a ground wire inside. It is connected to a 15 amp circuit breaker in the box in the basement. I'm assuming the current cable is 12/2, but if it happens to be 14/2 and I connect 12/2 to it inside a junction box, will that be a problem?
Thanks.
Lucas718 is offline   Reply With Quote
Old 05-25-2010, 10:23 AM   #2
joed's Avatar
Rewards Points: 11,516
If it is on a 15 amp breaker then 14/2 is all that is required even if your existing is 12/2.
Old 05-25-2010, 10:35 AM   #3
Thanks for the reply! I just took a flashlight and looked up into the hole in the wall and could make out a faint 14-2 on the cable, so it looks like I'm all set.
Old 05-25-2010, 10:48 AM   #4
Just call me Andrew
Rewards Points: 1,020
There is nothing wrong with 12/2 on a 15-amp breaker (12 is bigger than 14). You can oversize wire, and you have to in some cases (long distance). Your breaker size is limited by the smallest wire on the circuit.
14 gauge - 15A max
12 gauge - 20A max
The only reason that I can think of NOT to put 12/2 on a 15A circuit is that it is misleading.
Andrew
secutanudu is offline   Reply With Quote
Old 05-25-2010, 11:37 AM   #5
Since I'm essentially splicing 2 pieces of Romex together, do I connect the ground wire from each piece together like I would do with the whites & the blacks?
Old 05-25-2010, 11:48 AM   #6
joed's Avatar
Yes connect the gounds to each other and to the box if it is metal.
Old 05-25-2010, 07:11 PM   #7
Thanks for your help! After I wired a junction box into the upper cabinet, I was able to successfully install the range hood. And the best part is... it works! The wife is visiting her sister for a few days and I'm so happy I can surprise her with this when she gets back.
I love this site! You guys rock!
Identify age of old Romex - also funny ground Leah Frances Electrical 9 02-06-2012 01:07 AM
romex clamped against bx knockout in old box kbm774 Electrical 11 08-16-2010 02:53 PM
Better way of connecting cable loop to roller chain? deleyd General DIY Discussions 1 06-30-2009 11:52 PM
Connecting Romex at Panel Bocolo Electrical 14 02-21-2009 06:55 AM
Cost Difference Between Conduit & Romex Shawns4 Electrical 39 08-25-2008 06:01 PM
