Is Connecting Red Wire To Black Wire Dangerous? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-12-2012, 01:29 PM   #1
Cool
Is connecting Red Wire to Black Wire Dangerous?
Hello,
I took a shot at installing a ceiling fan for the first time and I would like to get advice if I did the wiring correctly. There were Black, Copper, Red, and White Wires coming from the ceiling. I read the instructions and connected the wires as stated on the manual. I was left with the Red wire. I called a friend up and he told me to connect the Red wires from ceiling to the Black Connections from Ceiling and Fan. The fan works but something is irking me inside thats telling me this is not safe. Could anyone with any know how in this subject guide me in the right direction?
pookasdad is offline   Reply With Quote
Old 03-12-2012, 01:33 PM   #2
Rewards Points: 2,516
Is there a 2nd switch at the location of the switch that turns the fan on?
Does the fan have a light fixture attached to it or is there only a fan?
hammerlane is offline   Reply With Quote
Old 03-12-2012, 01:33 PM   #3
Red wire should be for the light kit. If you don't have a light kit installed then no need to connect the red but no harm done.
Mike in Arkansas is offline   Reply With Quote
Old 03-12-2012, 01:55 PM   #4
joed's Avatar
Rewards Points: 11,988
Ceiling fans can use two hot wires. One is for the fan and the other is for the light. If you have two switches to control the fan then black and red are the two wires from the two switches. Depending on how they are connected at the switches depends on which one you connect the fan or the light at the ceiling.
The Following User Says Thank You to joed For This Useful Post:
plummen (03-13-2012)
Old 03-12-2012, 01:55 PM   #5
There is a 2nd switch but it goes to an outlet on the wall. So basically 1 Switch to turn on the fan.
Old 03-12-2012, 02:07 PM   #6
A Little Of Everything
Rewards Points: 1,364
Originally Posted by pookasdad View Post
Hello,
Sounds to me like you've got a 3-way switch setup. The ceiling fan instructions should tell you how to deal with that.
DrHicks is offline   Reply With Quote
Old 03-12-2012, 06:15 PM   #7
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Anything is possible you will need a meter to find out for sure. I would test the wires. Possible that red wire powers the switched outlet for a table lamp and the light kit for the fan. You will need to check what you have in the switch box and send pictures so we can help you better.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 03-12-2012, 06:38 PM   #8
Rewards Points: 1,192
Connect the red wire to the light kit wire for future use.
bobelectric is offline   Reply With Quote
ceiling fan wicked97 Electrical 4 08-21-2011 09:12 AM
Help with Two Switches & Two Lights simplyphp Electrical 36 11-25-2010 03:47 PM
Another dimmer question {also wik pic} Steve S Electrical 10 11-22-2008 11:31 AM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 09:58 AM
Red & Black wire from light = blown fuse leedslad Electrical 3 08-28-2006 07:54 PM
