Connecting Pool Pump And Pool Sanitizer - Electrical - DIY Chatroom Home Improvement Forum
Old 08-16-2008, 06:04 AM   #1
connecting pool pump and pool sanitizer
Hello.
I am connecting a pool pump and a pool sanitizing system. The sanitizng system states it must be synchronized with the pool pump. ( pump off sanitizer off etc) The wiring is 220v from a dbl pole 15amp gfci.
how would I connect both to operate as synchronized.
Skippy2 is offline   Reply With Quote
Old 08-16-2008, 06:12 AM   #2
Whatamess
You would need to connect both to a master switch or timer. I have mine hooked to a timer so it works at early morning to keep the sun from killing the chlorine.
I may go home hungry, but not tired and hungry.
TazinCR is offline   Reply With Quote
Old 08-16-2008, 06:27 AM   #3
OMG sorry it is very early here..
That would make sense.
Thanks.
When running 220v to the motor no neutral correct.. 2 hots and a ground?
TY
Old 08-17-2008, 11:51 AM   #4
Idiot Emeritus
Rewards Points: 1,492
Synchronized in this case means that the sanitizer must be energized only when the pump is also energized. The reason being is that if the sanitizer is energized while no water is running through it, it'll burn up.
Simply connect it to the same wires that feed the pump motor. If the pump motor is 220, make sure that the sanitizer is also 220.
220 consists of 2 hots, and a ground. No neutral.
Rob
micromind is offline   Reply With Quote
Old 08-17-2008, 11:56 AM   #5
Whatamess
Are you talking about a chlorine generator or what? What brand? Some you have to reconfigure for 220 or 110. If it is 110 you have to have the neutral.
Old 08-17-2008, 07:48 PM   #6
Yes a chlorine generator.. Duo Clear by Zodiac.. It is by default set to 220..
Thanks for all the help and clarification.. All is connected and running great. Inspection passed.
To all who responded and frequent here thanks. A great community and a huge service to all. I hope to help others on day like I was. I will visit frequently to pass on some of my knowledge when the opportunity arrives.
Thanks again and cheers
Bryan
New pool pump trips breaker?! New home owner needs advice. KenR7A Electrical 22 01-05-2011 09:42 AM
Pool Pump & Light Wiring Nod Electrical 28 07-15-2008 04:49 PM
Pool Pump Wiring mpdive Electrical 17 06-15-2008 07:30 PM
pool pump BillyD Plumbing 4 05-12-2008 10:07 PM
swimming pool pump wire steel Electrical 5 04-06-2008 08:35 PM
