Connecting Metal Conduit To Ceiling Fan Junction Box - Electrical - DIY Chatroom Home Improvement Forum
Old 04-18-2010, 02:04 PM   #1
Connecting metal conduit to ceiling fan junction box
I live in Chicago and spent some time yesterday examining whether I could install a ceiling fan where a light fixture had been. I'm leaning towards calling in a professional because I can't figure out how one would connect a ceiling fan rated box. I thought I'd post here to find out 1) if my current hypothesis is correct and 2) to know what to expect when I get estimates.
Old junction box had 4 top knockouts and 4 tubes of metal conduit were cut to length to end at/in the box. At the stores, none of the the "old construction" ceiling fan braces had more than 2 knockouts on the top. In other words, I got stuck because I didn't know how I would make the connection between the final few inches and the side knockouts on a new box. Hypothesis: use flexible metallic conduit for the final few inches (no splicing of wires will be necessary).
I'm curious how this problem is handled by others. Thanks for reading.
tabatt07 is offline   Reply With Quote
Old 04-18-2010, 02:41 PM   #2
joed's Avatar
Rewards Points: 12,032
Cut/drill the needed holes.
Attach the existing box to your new fan brace.
Old 04-20-2010, 06:43 AM   #3
That solves one problem but how would the fan be mounted to the box? I read that ceiling fans should not be attached to dog ears.
Old 04-20-2010, 07:30 AM   #4
Just call me Andrew
Rewards Points: 1,020
Take a look at a fan-rated box - they have dog ears too. Your metal box will be fine. I think the fan rating has more to do with the box coming off of the ceiling than the fan coming off of the box.
Andrew
secutanudu is offline   Reply With Quote
Old 04-22-2010, 09:31 PM   #5
skidrowpete
Rewards Points: 12
your local electrical distibutor has an electricl fitting that takes two[2] mc or greenfield cables that will fit in a 1/2 inch ko problem solved for 4 cables in 2 holes skidrowpete
skidrowpete is offline   Reply With Quote
Old 04-22-2010, 11:05 PM   #6
Rewards Points: 338
tabatt07, If you've checked HD or Lowe's try an electrical supply house next. Since Chicago requires everything to be run in conduit, that would be your best choice. The dog ears for fan rated boxes are a little more substantial than a standard 4" octagonal box, to support the weight/motion of the fan. A properly balanced fan should have minimal side to side motion. Good luck, petey
petey_c is offline   Reply With Quote
Old 04-26-2010, 01:03 AM   #7
Union Electrician
goose134's Avatar
If you've got an old Chicago house with the iron pancake box and rigid pipe, you'll be fine hanging a fan on it. The box itself should be supported with a steel rectangular bar through the top, plus the hits of rigid. The screws are only 8/32 so I usually drill and tap for a larger screw into the body of the box.
I'm in the city and have seen a lot of these.
goose134 is offline   Reply With Quote
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 09:26 AM
Chicago Conduit Rules Wrigleyville Electrical 6 01-28-2010 07:49 PM
Junction boxes for garage T8 fixtures mazeroth Electrical 13 01-25-2010 10:52 PM
Ceiling condensation icemand Building & Construction 1 12-15-2009 06:16 AM
Advice for installing ceiling fan Ceiling Fan Man Electrical 5 06-02-2009 05:18 PM
