Connecting LSM-15 As Single Way Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 12-30-2012, 12:54 AM   #1
Rewards Points: 16
Connecting LSM-15 as single way switch
I need to hook up a LSM-15 as a single way switch.
http://www.homeseer.com/pdfs/Evolve/LSM-15_SPEC.pdf
I tried hooking up the black and white with no luck.
It has Black, White, Blue, Yellow and Green.
The instructions are not clear on what the wiring should be for a single switch.
2bsure is offline   Reply With Quote
Old 12-30-2012, 06:21 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
Connect the incoming power to the black and white, connect the load to the blue.
If you only have a single black and white wire in the switch box, you have a switch loop (no neutral) and cannot use that switch.
Coastal South Carolina
Old 12-30-2012, 09:36 AM   #3
Rewards Points: 16
The old switch had two wires connected that both are black. There are a bunch of other wires bundled up in the box as well.
So on new switch and can twist together the black/white onto the incoming hot wire and then tie the blue onto the load wire?
Old 12-30-2012, 09:51 AM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 594
No,... Ya need a different switch....
Bondo is online now   Reply With Quote
The Following User Says Thank You to Bondo For This Useful Post:
rjniles (12-30-2012)
Old 12-30-2012, 10:56 AM   #5
Rewards Points: 320
Is this nm cable or conduit? Sounds like you are just replacing a single pole switch with the new one, which is okay, as long as you have a neutral in the switch box. If this is nm cable then it sounds like you do since you have two black wires on the switch. The neutral from the new switch gets wire nutted to the neutral wires. The power feed goes to the black wire and the load to the light (black) wire goes to the blue.
teamo is offline   Reply With Quote
Old 12-30-2012, 01:00 PM   #6
A "Handy Husband"
rjniles's Avatar
Is there a bundle of white wires in the back of the box? If so that is the neutral and connects to the new switch white. Of the 2 blacks connected to the switch, you need to determine which is the hot feed and connect to the black of the switch. The other black will be the load and connects to the blue. You need a multimeter to test for the hot lead.
Double switch and single switch in same box? Mallard1123 Electrical 2 09-19-2012 12:06 PM
Help with single pole switch that has me baffled NABRIL Electrical 19 03-12-2012 06:37 AM
Powering a new single pole switch off of an existing three way switch set? jamesm067 Electrical 3 01-17-2012 08:36 AM
Single Pole Light Switch with 4 Wires dmwiecz Electrical 6 11-22-2010 07:41 PM
Three way switch to single? idscnyco Electrical 5 10-04-2010 02:38 PM
