Connecting Lights To 20A Circuit - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 09-04-2013, 09:31 PM   #31
dmxtothemax's Avatar
Rewards Points: 5,098
Any one know why they don't like lights on Small Appliance Branch Circuits ?
There must be a practicule reason for it ?
dmxtothemax is offline   Reply With Quote
Old 09-04-2013, 11:08 PM   #32
kevinp22's Avatar
Safety reasons -- SABC carries some serious loads. A toaster might draw 10, a George foreman grill 12 etc. the lights would just take up much needed capacity. plus blown circuit leaves you in the dark.
Practical Reason -- lights dim when appliances turn on. very annoying. my kitchen (before I rewired it) had a "master circuit" with just about everything on one.
kevinp22 is offline   Reply With Quote
Old 09-05-2013, 06:59 AM   #33
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
They are required for actual small appliances... no particular safety reason, just the fact that the kitchen area is going to have appliances that require more circuits.
Old 09-06-2013, 04:43 PM   #34
I'm told that this applies to more than just lights. I planned on wiring a hood fan to a SABC but the code states that "no outlets" shall be connected to SABC. I assume this applies to garbage disposals, local water filter (i.e,. mine has a small pump), and whatever else you may have that doesn't plug into the receptacles on the counter top.
I think NEC has gone a little too far with the SABC code. They already require a minimum of 2 SABC 20A circuits in the kitchen besides having separate circuits for a dishwasher and fridge. In my case, I have 4 SABC 20A circuits in my kitchen plus a 20A circuit for a dishwasher, a 20A circuit for a fridge, and a 20A circuit for a garbage disposal and water filter. I also have a 50A circuit for a cooktop and 30A circuit for an oven and a 15A circuit for lights. Given all this power, one would think that I have a massive kitchen but it only measures 10'x14'.
I think NEC should have specified a minimum total available power for small appliances--that is, total "uncommitted power" at the receptacles -- and let the owner distribute the power to best suit the kitchen layout. In my case, I had a single circuit that fed a receptacle at a 24" counter space on one side of the stove and it also fed a hood fan. This arrangement is against code. I had to either connect the receptacle to another SABC or connect the hood fan to a non-SABC circuit.
Another example is that it is okay to plug a microwave into a SABC receptacle but not okay to direct wire a microwave to a SABC.
rojo527 is offline   Reply With Quote
Old 09-06-2013, 09:37 PM   #35
Semi-Pro Electro-Geek
Rewards Points: 2,860
That's right. SABC's are for countertop receptacles only. Nothing else.
I think NEC has gone a little too far with the SABC code. They already require a minimum of 2 SABC 20A circuits in the kitchen besides having separate circuits for a dishwasher and fridge. In my case, I have 4 SABC 20A circuits in my kitchen plus...
There are only two SABC's by code. Any other circuits would not be designated as SABC's, and could have whatever you want on them.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
Old 09-07-2013, 11:45 AM   #36
E2 Electrician
That is simply untrue.... I can wire my kitchen and dining room receptacles on the same circuit, I do need two circuits for the countertop area though.
Old 09-07-2013, 11:46 AM   #37
E2 Electrician
Your logic on the subject is ignorant... you simply don't understand what they are trying to accomplish.
The Following User Says Thank You to stickboy1375 For This Useful Post:
jbfan (09-07-2013)
Old 09-08-2013, 04:00 PM   #38
I'm confused. Isn't that exactly the same thing I said? Only countertop receptacles can be on a SABC, nothing else. But you can have as many non-SABC circuits in the kitchen as you want, as long as you have the two required SABC's that serve nothing but kitchen receptacles.
EDIT: I see what you mean. You're right. The SABCs can supply other food service areas in addition to the kitchen countertops, as long as they also serve the kitchen countertops and do not serve non-food-service areas.
Old 09-08-2013, 08:34 PM   #39
" Euro " electrician
frenchelectrican's Avatar
Bonjour Dmxtothemax.,
In France our codes we do not allow any lumiaires on the SABC ( SABC ) either and that was written for very obovus reason due if you do trip the SABC the luminaries go out you are stuck in dark so that one reason why we don't allow it.
Second thing the luminaires are on it own circuit. ( normally we do minuim of 2 or more depending on the luminaire and set up )
We know it was written in NEC code for a quite while I think it was enforced sometime early 80's but I do not have the NEC code book that go that far back so hard to say but I know in my old '84 NEC edition it did mention there.
Merci,
Marie et Marc
Old 09-09-2013, 12:20 PM   #40
I think you made my point. I hear several electricians interpret the same codes differently, all claiming to know what was intended but not knowing how to explain it other than saying "you simply don't understand."
The NEC states the electrical codes, most of which are unambiguous and fairly obvious as to the reasons behind it, others subject to interpretation and only a guess as to why the code exists. I'm sure the concept of a small-appliance-branch-circuit has some basis but it's intention is not stated in the NEC. I suppose this is not unlike any book of laws and maybe it's the best we can do. So be it.
Old 09-09-2013, 06:17 PM   #41
Merci,
Marie et Marc
This is why we here in Australia dont put lights on the same circuits as power points,(you would call them recepticules).
Lights have there circuits,
And power points have there own circuits.
So hopefully if you blow a circuit, usually its a power circuit,
then your not in the dark.
The Following User Says Thank You to dmxtothemax For This Useful Post:
frenchelectrican (09-12-2013)
Tags
12/2 vs 14/2 , light restrictions , nec code
Circuit Breaker Arcs, Buzzs and Lights Flicker HELP! jbean8510 Electrical 5 03-05-2013 10:35 AM
Arcing between circuit breakers and flickering lights mscotter Electrical 12 07-13-2012 01:46 AM
How many outlets and lights on a circuit lowvolter Electrical 14 12-28-2011 11:14 AM
Maximum lights on a single circuit sbazzle Electrical 3 02-15-2011 09:43 AM
Should Ceiling lights be on separate circuit? handyoldgal Electrical 29 03-18-2009 09:54 PM
