Connecting LED Light String To Plug - Electrical - DIY Chatroom Home Improvement Forum
Old 06-12-2009, 01:37 PM   #1
Connecting LED light string to plug
Hello fellow DIY'ers! I am going to build a string of leds and im somewhat of a noob when it comes to electrical work...
Im going to be using the lighting for agriculture, and I found these high power Cree LED's that look like they could do the trick
link: http://www.dealextreme.com/details.dx/sku.1776
my question is how would I go about getting the whole thing set up? Someone posted a link in the review area that says this can handle 10 of them (link below)
link: http://www.dealextreme.com/details.dx/sku.13557
Are those 2 parts all I need to get it running? I have an old power chord that i can cut up and connect to the 2nd part to give it the edison plug (will that work?)
Thanks guys, im sorry if this is hard to understand because I dont know much and I am having a hard time explaining it. I hope you understand what I meant.
Cheers!
-Harbringer
Harbringer is offline   Reply With Quote
Old 06-12-2009, 03:31 PM   #2
The LED driver can only handle 1 or two LEDs, you would also need a step down transformer of a DC power supply. You can not connect the LED direct to 120 VAC.
hayewe farm is offline   Reply With Quote
Old 06-12-2009, 04:21 PM   #3
Thanks for the heads up hayewe farm!
What type of step down transformer of a DC power supply would I need? Also someone on the review area mentioned tat driver could handle a string of 10, they could be wrong though. What do I look for in a LED driver in terms of being able to handle more lights on the string?
Thanks, -Harbringer
Old 06-13-2009, 07:08 PM   #4
The LED array operates on 1.9 to 2.2 volts DC.
the driver requires 12 to 16 volt input AC or DC the wright up says it will handle current for 3 LEDS
porch light and string lights sawtooth Electrical 5 10-03-2008 08:30 AM
Connecting a Ceiling fan to a Light Switch AceAvenue Electrical 6 06-03-2008 04:06 PM
Shed: One light, one plug Crackers Electrical 2 08-31-2007 06:09 PM
Polarized plug light fixture- Hardwire to home electrical? timdavis3824 Electrical 3 07-09-2007 01:34 PM
converting hanging light fixture to plug dukeswalker Electrical 2 09-18-2006 10:03 PM
