Connecting An Inverter - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-03-2014, 09:19 PM   #16
Thanks for all the information. I was looking into pure sine wave inverter from the start. A 5kw one does seem like a better fit. I am thinking that I would need 10gauge wire to hook that up right? Just want to double check I know 10gauge will do 30amps or would I need to used 6 gauge? I think that's rated to 80 if I remember correctly. As for batteries I found some pretty good 200ah deep cycles for a reasonable price. I was thinking of a 24v system because it would mitigate me having to use 0000 gauge cables for battery hook ups. That would give me about an hour of run time. Maybe a little more if I am willing to go to 20% charge which I would rather avoid. The generator idea is good and I do have one but I hate having to run outside and power it up and a lot of times the outage last less than 20 minutes. Usually if its over 20 minutes we are out for at least 8 hours. With a 1 hour run time I would mitigate like 80% of my trips to the generator. I use a 3500w generator and it seems to run things fine. I connect a PC ups to the fridge whenever I run it since it outputs a modified sine wave. I wish I could just wire up a rack Mounted ups unit into the system and be done with it.
ericm115 is offline   Reply With Quote
Old 04-03-2014, 09:32 PM   #17
Rewards Points: 746
Hard wired UPS's are available.
If you intend to use this for less than an hour why even bother with the refrigerator/freezer? They can go hours and maintain temperature. Then you could get by with a much smaller unit, at much lower cost.
I wouldn't bother with the UPS for the fridge. It'd be much happier even with a "dirty" sine wave than a "modified" one.
AandPDan is online now   Reply With Quote
The Following User Says Thank You to AandPDan For This Useful Post:
mpoulton (04-03-2014)
Old 04-03-2014, 10:13 PM   #18
Semi-Pro Electro-Geek
Rewards Points: 2,900
Yeah, blocks of ice are a much better "UPS" for a freezer in the short term. This sure seems like an expensive and inefficient alternative to a generator. The purpose of a UPS is to provide instant changeover for loads that can't go down at all, like servers. Most built-in UPS installations use the UPS as a very short-term bridge between utility failure and generator startup.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
Inverter power Centex2011 Electrical 15 12-29-2013 10:56 AM
Automatic switching On/Off the incoming AC Mains for Inverter digimart Electrical 0 10-13-2013 05:15 PM
Solar storage battery and inverter john monge Green Home Improvement 5 09-19-2013 11:02 AM
Troubleshooting Lighting Circuit with Power Inverter smusick Electrical 3 11-01-2011 09:56 PM
Inverter wiring to panel speedymonk Electrical 26 10-18-2011 08:42 PM
