Connecting Hot Water Heater - Electrical - DIY Chatroom Home Improvement Forum
Old 03-01-2009, 05:51 PM   #1
Connecting hot water heater
I'm located in Canada but I do not think that maters much in this case.
I'm DIY'ing my 1st hot water heater. The old hot water heater is GAS while the new one is electric. I'm taking my time since the old hot water heater has not failed yet.
The electric tank is 4500W. I bought and ran 10.2bx cable and i'm going to connect it to a double pole 30a breaker.
After I ran the cable, I noticed that the heater wires are 12 gauge. Is it a problem to connect the 10.2 to the 12 gauge wire?
unixb0y is offline   Reply With Quote
Old 03-01-2009, 06:04 PM   #2
" Euro " electrician
frenchelectrican's Avatar
If the conductors are from factory no it will not be a issue with it.
It kinda common to see that due the factory conductors have diffrent tempture rating than the standard building conductors are.
Merci,Marc
Old 03-01-2009, 07:51 PM   #3
4500/240 = 19 Canadian Amps?
Old 03-01-2009, 08:01 PM   #4
To confirm Frenchelectrician, the insulation value on the HWT wiring allows you to connect the 30 amp 10AWG circuit to the HWT.
unclduey is offline   Reply With Quote
Old 03-01-2009, 09:29 PM   #5
The tank manual sugests a 25amp double pole breaker. I was only able to find a 30 amp double pole for my pannel
Old 03-01-2009, 09:35 PM   #6
The min size is 25 amp breaker but use the 30 amp breaker is far more common to do that.
Unless you can order that size it will cost more than the common size breaker what most big box store will stock them in there.
Merci,Marc
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Water Heater Problems martyshel Electrical 4 01-24-2009 12:07 AM
Multiple hot water heater issues a-6intruder Plumbing 8 01-16-2009 05:58 PM
Electric Water Heater GTSRider Plumbing 31 12-07-2008 11:30 AM
Water Heater tsmith Plumbing 10 12-01-2008 06:24 PM
