Connecting To Electrical Box - Electrical - DIY Chatroom Home Improvement Forum
Old 08-24-2012, 09:21 AM   #1
Connecting to Electrical box
I am finishing out my basement and installing 3 new circuits and just need to know which is the best way to run the wires to the electrical box. Picture below.
Just need to know what would be the best option:
1. Run wires through the top with the rest of them, which seems a little dangerous with the main lines coming in and the wires in there are tight or
2. Run them to the bottom of the electrical box so that the 3 new circuits run to the bottom of the electrical box and connect up that way.
buildit45 is offline   Reply With Quote
Old 08-24-2012, 09:37 AM   #2
Special User
Rewards Points: 1,230
If you want to go out the top, you should break open an additional knockout so your branch circuits aren't sharing an opening with the incoming feed.
tylernt is offline   Reply With Quote
Old 08-24-2012, 09:59 AM   #3
Rewards Points: 3,256
I had to blow your pic up a bit to understand what was going on with the conduit. Does every circuit for your house go into that conduit? Are your main service wires in that conduit as well or do they come into the back of your panel?
zappa is offline   Reply With Quote
Old 08-24-2012, 03:35 PM   #4
Licensed electrician
Rewards Points: 1,752
There are 1/2" knockouts in the top of the panel.
Old 08-24-2012, 04:09 PM   #5
As said above..Are all your current house circuits running in that one conduit???AND your mains???
Wow, just wow. Looks pretty but wow, where do I begin?
Anyway. If you don't want to use that existing piece of conduit. And I recommend you don't. Then you can come in the top or bottom as you see fit, it does not matter. Use appropriate fittings when you bring your romex in.
parman is offline   Reply With Quote
Old 08-24-2012, 08:41 PM   #6
Rewards Points: 2,516
provide a picture of the top of the panel
hammerlane is offline   Reply With Quote
Old 08-24-2012, 09:17 PM   #7
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Where is the panel fed from or is that the feed up top?
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 08-24-2012, 09:28 PM   #8
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Eliminate that conduit, because it doesn't meet code.
Old 08-24-2012, 09:54 PM   #9
electures's Avatar
Why not?
Old 08-25-2012, 07:34 AM   #10
Rewards Points: 3,130
Is this a subpanel? I can't imagine that the cables for all the circuits in your house run through that conduit - it looks way too small for that.
Old 08-25-2012, 07:42 AM   #11
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,968
No, show a pic with the cover off.
The Following User Says Thank You to Speedy Petey For This Useful Post:
electures (08-25-2012)
Old 08-25-2012, 08:01 AM   #12
I have not taken off the panel as of yet so I do not know if the main lines run into the back of it. I have not touched anything on this panel as of yet, the house was built in 2006 and I am the only person who has lived in it. So from my understanding when I look at the top of the panel all the wires from the house run through the top and there is no sub pannel.
In regards to this not being to code according to my local building code
"Services and feeders. All service entrance and feeder conductors installed in or on single-family and two-family dwellings shall be installed in approved raceways. All service entrance and feeder conductors for multi-family dwellings and associated buildings shall be installed in approved raceways."
So from what I am finding out from here is to in from the bottom.
Old 08-25-2012, 08:15 AM   #13
Well, as you can see, that is for "service entrance and feeder conductors". They are asking about the branch circuits.
Also, knowing your location would help since some areas have very specific code and rules.
The ONLY way we can tell you anything for certain is after seeing a pic with the cover off.
Old 08-25-2012, 08:22 AM   #14
electures's Avatar
If that is the main panel and all the branch circuits run through one conduit, you got problems.
2 TVs fried: Electrical vs. Comcast Coax Cable Problem LynOprinka Electrical 17 07-16-2012 08:01 PM
Electrical Questions from a Foreigner mark_anderson_u Electrical 4 09-10-2010 06:46 AM
For stacked dryer/washer - where to locate electrical outlets and water supply lines Cliffhanger Electrical 3 09-05-2010 09:48 AM
Electrical Panel Upgrade & Main Water Shut Off DIYerIT Electrical 2 09-02-2010 02:42 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
