I purchased a coxreel with an electric motor. The motor came with a switch to connect to the to the electric motor that in on the cox reel and a 12 volt marine battery.
The switch is a metal box that has the switch solenoid and circuit breaker. I know little to nothing about hooking such an electrical switch. Here is what is in the box
-The solenoid has two large bolts connections and then a 3rd smaller nut/bolt connection
-The switch has two smaller Phillips screws which look like wires should hook up to them
-The circuit breaker has two bolts/nuts that look like wires should connect to them
The electric motor has two wires off of it
The battery is a marine battery with a positive and negative terminal
I am not sure how all of this hooks up together. I am also unsure what gauge wire I should get to connect all of this up. I have enclosed some pictures of the switch containing the solenoid, breaker, and switch as well as the electric motor
Thanks for any help
Thanks for any help
