Connecting Conduit To Subpanel - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-07-2008, 10:45 AM   #16
Rewards Points: 246
Originally Posted by rgsgww View Post
Oh, never mind. All you have to do is ream the conduit, right?
Yeah, I can see where its a good thing with large wires.
Remember we are talking PVC not RMC.
Old 12-07-2008, 11:08 AM   #17
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
Originally Posted by xv144 View Post
Square D QO QO124L125G LOAD CENTER - $55 on Ebay for brand new with cover and ground bar.
I was going to buy a panel off of ebay, then I got scared when I read that CH warned not to buy outside of authorized retail channels because of counterfeit products that are on the market.
Did the panel looks just fine, all look brand new? Did you buy it from the panel king guy on e-bay?
Jamie
jamiedolan is offline   Reply With Quote
Old 12-07-2008, 02:33 PM   #18
DIYer
They probably won't bother counterfeiting a panel, the breakers are what you need to worry about. Especially expensive breakers like GFCI and AFCI.... they want the fat profit margins where it's easier to hide shoddy workmanship. Hard to cheapen up a panel, easy to just leave the guts out of a AFCI.
Gigs is offline   Reply With Quote
Old 12-07-2008, 08:07 PM   #19
Panel looked brank new, not a mark on it. From "Panel Peddler" on eBay.
xv144 is offline   Reply With Quote
Old 12-07-2008, 08:49 PM   #20
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,992
You are in PA right? Are there no electrical supply houses, or even a Home Depot in your area?
WHY are you buying panels and breakers off Ebay???
You could have gotten a 100A main breaker panel for the same $55 (or less) that you got your Ebay special used panel for.
Also, WHY are you backfeeding a main lug panel? Were you aware that you could have used a 100A main breaker panel and be done with it? There was NO need to use the same 60A breaker to backfeed. A 100A main breaker would simply serve as a disconnect.
The 60A breaker in the main panel is your overcurrent protection for the feeder.
Old 12-08-2008, 12:15 AM   #21
DIY'er
jamiedolan's Avatar
I ended up buying everything (2 CH panels) from menards, I just didn't think it was worth the risk, even though the seller had a good rating and stated all products are brand new.
Jamie
Old 12-08-2008, 06:52 AM   #22
The local electrical store only sells Siemens brand. I wanted to stick with my main panel brand, Square D.
Ebay was cheaper than Home Depot. From what I have read, only the Square D circuit breakers have been counterfeited, and there are obviious ways to tell (e.g. number not printed on the switch, different shape connector).
In my first post in this forum several suggested backfeeding the subpanel. From my pricing using a Circuit Breaker as a switch was cheaper than buying a panel with a switch.
I'm sure there are several ways to do this, other than my abandoned idea of using a 'used breaker', I don't see anything wrong with my plans.
Adding a subpanel to a sub-panel and other questions CardinalPilot Electrical 14 03-30-2011 02:23 PM
Another subpanel question:) primal65 Electrical 15 06-22-2008 09:43 AM
Connecting subpanel to main panel rtyui2 Electrical 10 12-07-2007 06:29 PM
Wiring 100A subpanel nebulous Electrical 9 08-29-2007 02:41 PM
