Old 05-30-2008, 10:11 AM   #1
Question Connecting a Ceiling fan to a Light Switch
Hi,
I believe I have a pretty complicated question and would really appreciate any assistance.
I just converted my garage into a room and am trying to install a ceiling fan. I currently have the wires from the breaker box connecting 3 new power outlets and the 3rd outlet wires go to the ceiling fan. I then have another wire going from the ceiling fan to the light switch.
Right now having the light switch on or off doesn’t make any difference. The ceiling fan and all the outlets are powered.
I have 2 questions.
  • How do I get the light switch to control the ceiling fan?
  • Once I do, is turning the light switch off also going to turn off my 3 outlets and if so is there any way to make it just control the ceiling fan?
Thanks for your help.
AceAvenue is offline   Reply With Quote
Old 05-30-2008, 12:59 PM   #2
Licensed Electrician
jrclen's Avatar
Originally Posted by AceAvenue View Post
Hi,
I have 2 questions.
At the ceiling fan, connect the white and the ground from the outlet to the fan white and ground. Connect the ground going to the switch to the ground at the fan also. Connect the white going to the switch to the black from the receptacle, at the fan box. Connect the black going to the switch to the black fan wire. Connect the white and black and ground to the terminals on the switch. This will allow the switch to control the fan and have no effect on the receptacle outlets. Remember to turn off the circuit before wiring.
John
jrclen is offline   Reply With Quote
Old 05-30-2008, 04:21 PM   #3
This is how you need to wire it.
http://www.selfhelpandmore.com/image...ightswitch.gif
Old 05-30-2008, 04:48 PM   #4
That makes total sense to me. Great Directions jrclen. I will try it this evening.
THANK YOU!!!
Old 05-31-2008, 11:13 AM   #5
jrclen's Avatar
That sure would make a big snap and trip the breaker. The diagram makes it look like the hot and neutral line conductors into the fixture are both connected to the switch.
John
Old 06-03-2008, 10:50 AM   #6
Worked Perfect...Thanks!
Old 06-03-2008, 05:06 PM   #7
jrclen's Avatar
Glad to hear that. You're welcome.
John
Tags
ceiling fan, electrical, light switch, new ceiling fan, new electricity
More On This Topic
Hi! I'm Chad Smith and I'm a State Certified Journeyman wireman; basically an electrician. I'm here today with expertvillage.com and we just finished installing this ceiling fan. Now all we have to do is go out and flip the power back on and come back in... Read More »
Hi! My name is Adolph Ramirez from Tampa, Florida on behalf of Expert Village, this is how to install a ceiling fan. Make sure you disconnect all of your power; shut it off at the service panel. Don't rely on any kind of switches or anything like that... Read More »
Hi! I'm Chad Smith and I'm a State Certified Journeyman wireman; basically an electrician. I'm here today with expertvillage.com and we are hanging a ceiling fan in this house. Now we've already been through all the steps of shutting the power off... Read More »
Hi! I'm Chad Smith and I'm a State Certified Journeyman wireman; basically an electrician. I'm here with expertvillage.com today and we just finished installing a ceiling fan in this house. I just want to take a brief moment and talk about dimmer... Read More »
Hi! I'm Drew Finn and I am here for expertvillage.com. I am a professional home inspector and we are going to show you how to install a ceiling fan today. Okay, now we've got the dates here all set. We hang it on that loop so that we can work on the... Read More »
Adding new ceiling light in place of switched outlet XavierG35 Electrical 2 02-13-2008 11:05 PM
Moved ceiling light in bedroom to center, now trips breaker blthomas Electrical 18 01-24-2008 06:29 PM
Ceiling Fan Light Switch Replacement leanthinkin Electrical 2 08-22-2006 02:10 PM
Wiring double switch for new ceiling fan toolmanwannabe Electrical 16 08-13-2006 05:52 PM
ceiling fan light switch replacemnet thomasr1950 Electrical 1 03-18-2006 04:42 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
