-   -   Connecting a Ceiling fan to a Light Switch (http://www.diychatroom.com/f18/connecting-ceiling-fan-light-switch-21642/)
AceAvenue 05-30-2008 08:11 AM
Hi,
I believe I have a pretty complicated question and would really appreciate any assistance.
I just converted my garage into a room and am trying to install a ceiling fan. I currently have the wires from the breaker box connecting 3 new power outlets and the 3rd outlet wires go to the ceiling fan. I then have another wire going from the ceiling fan to the light switch.
Right now having the light switch on or off doesn’t make any difference. The ceiling fan and all the outlets are powered.
I have 2 questions.
  • How do I get the light switch to control the ceiling fan?
  • Once I do, is turning the light switch off also going to turn off my 3 outlets and if so is there any way to make it just control the ceiling fan?
Thanks for your help.
jrclen 05-30-2008 10:59 AM
Originally Posted by AceAvenue (Post 126770)
Hi,
I have 2 questions.
At the ceiling fan, connect the white and the ground from the outlet to the fan white and ground. Connect the ground going to the switch to the ground at the fan also. Connect the white going to the switch to the black from the receptacle, at the fan box. Connect the black going to the switch to the black fan wire. Connect the white and black and ground to the terminals on the switch. This will allow the switch to control the fan and have no effect on the receptacle outlets. Remember to turn off the circuit before wiring.
joed 05-30-2008 02:21 PM
This is how you need to wire it.
http://www.selfhelpandmore.com/image...ightswitch.gif
AceAvenue 05-30-2008 02:48 PM
That makes total sense to me. Great Directions jrclen. I will try it this evening.
THANK YOU!!!
jrclen 05-31-2008 09:13 AM
Originally Posted by joed (Post 126836)
That sure would make a big snap and trip the breaker. The diagram makes it look like the hot and neutral line conductors into the fixture are both connected to the switch.
AceAvenue 06-03-2008 08:50 AM
Worked Perfect...Thanks!
jrclen 06-03-2008 03:06 PM
Glad to hear that. You're welcome.
