Connecting Ceiling Fan With Light - Electrical - DIY Chatroom Home Improvement Forum
Old 10-31-2012, 01:45 PM   #1
Unhappy
Connecting ceiling fan with light
I had a light controlled by 2-3way switches which I replaced with a ceiling fan/light. The light works fine, but I want to connect a 2way switch to the network to control the fan separately,how do I connect this up?
power01 is offline   Reply With Quote
Old 10-31-2012, 03:02 PM   #2
how many wires are there at the fan box? did you wire the fan and light together on the existing switch so you can pull the chain to control the fan? if it wasn't wired originally for a fan and light you will have to run another wire from the switch location to the fan box or replace the wire that is there now with a 3 wire.
pictures of the wires in the fan box and the switch box usually help everyone give you the best answer.
Old 10-31-2012, 04:46 PM   #3
ceiling fan
I have 3-14/3 cables (6 conductors) plus copper grounds in the fan box, 1 cable power supply, (black & white) continued from other lights, I cable (black & white) from 3-way switch, and 1 cable (black & white) from a 2-way switch which I added, presently connected to nothing. The grounds are all connected to the box. The blue from fan connected to black power supply, the white power supply connected to a black from 3-way switch, white from 3-way switch connected to white from fan. The light works fine with both 3-way switches. When I had the rest of the wires connected, I could get the fan to work off the added switch, but only when the light is on.
Old 10-31-2012, 04:51 PM   #4
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
First of all, it seems you are switching the neutral. You cannot do that.
If you are using a 3 way switch, what do you have on the third terminal of the switch?
From what you are describing, it makes no sense and we would have no idea what to tell you to do. We need to know how many of each wire at each box, what you are trying to do, and how you currently have it wired up.
If you have 3 14/3's you would have 9 conductors plus grounds, not 6. Are you counting the ground when you say 14/3? If so, you are incorrect in your terminology. 14/3 is 3 insulated conductors plus a bare ground.
Old 10-31-2012, 04:58 PM   #5
k_buz's Avatar
Ok, assuming you are saying you have 3 14/2's at the fan box not 14/3...
Do you know what a 3way switch is? Where is the second 3 way switch? What wires run to the OTHER 3 way switch?
Old 10-31-2012, 05:20 PM   #6
ceiling fan
I am so sorry, I should have said 3-14/2 cables. That's what happens after trying to get this right for so long. Yes, ! know what a 3-way switch is. One is at the top of the stairs, and the other is at the bottom of the stairs. The light is controlled (on or off)from either location. The fan/light is close to the switch at the bottom of the stairs. I want the light to work as is on the 3-Ways but, I want the 2-way to turn the fan off/on independently whether the light is on or off. I have to leave now, trick or treats are beginning. I might come back later tonight. Thanks for your quick responses.
Old 10-31-2012, 05:36 PM   #7
k_buz's Avatar
I don't normally do this, but here is a diagram....
The Following User Says Thank You to k_buz For This Useful Post:
power01 (10-31-2012)
Old 10-31-2012, 06:23 PM   #8
where did you connect to get the power for the single switch for the fan?
Old 10-31-2012, 06:50 PM   #9
ceiling fan
I tried temporarily to connect to extension cord, didn't work. The 3-ways are wired as follows:
Downstairs switch (near Fan/light):
White wire - common screw (odd color, copper)
Red wire- Brass screw
White wire - Brass screw
2 Black wires nutted together
Upstairs Switch
Black wire - Common screw (odd color, copper)
Red wire - Brass screw
Switches work well with light.
How should I do the rest of the wire connections?
Old 10-31-2012, 06:54 PM   #10
k_buz's Avatar
Does no one see my diagram?
Old 10-31-2012, 10:49 PM   #11
Thank you very much for your diagram K buz appreciate it very much I will try it tomorrow, Thanks again.
Old 11-01-2012, 12:16 AM   #12
Sounded to me that in the op's second post, he was describing and has the feed and the switch leg to the three ways mixed up. Be careful when you hook up you are sure which is the feed and which is the switch leg. Or like k buz said you could end up switching the neutral.
Marc05 is offline   Reply With Quote
Old 11-01-2012, 01:03 PM   #13
ceiling fan
Well, I hooked it all up as per K buz's diagram and everything works perfectly. I can't thank you all enough especially K buz. I wish I could have found you 3 days ago. Thank you again and if you are ever in my neck of the woods, stop in for a cold one or a strong one or both. Thank you again and again.
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 52 11-05-2014 05:28 PM
confusion with track light stephenbishop Electrical 7 03-10-2012 02:37 PM
Removing old light fixture & install ceiling fan sjk Electrical 3 04-17-2011 09:32 AM
Cannot get new kitchen ceiling light to go off dbev07 Electrical 15 11-18-2008 01:27 PM
Ceiling light abuse! shurik57 Electrical 5 11-26-2007 11:30 AM
