Connecting 30 Amp Receptacle To 40 Amp Breaker, Please Help - Electrical - DIY Chatroom Home Improvement Forum
Old 05-11-2015, 03:02 AM   #1
Rewards Points: 2
connecting 30 amp receptacle to 40 amp breaker, Please Help
i am planning on changing my existing stove's receptacle into a 30amp-125/ 240v dryer's receptacle. is it safe to do so? should i be concerned the new receptacle is a 30 amp receptacle and the existing wire is higher ? the existing stove's receptacle is wired to a dual pole 40 amp breaker, and i believe is a 8 gauge wire. its a 4 prong receptacle.
Is this safe? can i just change the outlet only and still uses the existing wires?
also my dryer's cord doesn't reach the outlet, can i make an extension cord? using 10 gauge wires, with a 30 amp plug and connector? or what's my better option, since relocating the dryer closer to the outlet is a problem.
dientho is offline   Reply With Quote
Old 05-11-2015, 04:42 AM   #2
Rewards Points: 1,832
Larger wire sizes are ok, but the breaker must not go over the receptacle. In this case a 30amp NEMA 14-30 must have a 30amp breaker. And you are positive the cable has 4 wires?
I would avoid an extension cord and turn the outlet box into a splice box and run 10 gauge wire over to a new box with a new dryer receptacle.
Jump-start is offline   Reply With Quote
Old 05-11-2015, 01:34 PM   #3
Oso954's Avatar
Rewards Points: 420
If this is an apartment (or other rental), you cannot change that receptacle. You would have to get the management to do it.
Oso954 is online now   Reply With Quote
The Following User Says Thank You to Oso954 For This Useful Post:
Chris130 (05-11-2015)
Old 05-11-2015, 01:50 PM   #4
Is it just me or are we seeing an uptick in the number of people trying to jury rig a dryer ? Do it right and build a proper space for the dryer with the proper electrical and venting.
jimn01 is offline   Reply With Quote
The Following User Says Thank You to jimn01 For This Useful Post:
Separate 110 and 220 receptacles on 2-pole 220 V Square D GFI breaker sunrise Electrical 1 05-13-2012 08:27 PM
Connecting LB to Breaker Panel tedallen Electrical 5 05-06-2012 12:26 PM
GFCI Breaker Tripping Spa Light eaposition Electrical 21 09-08-2010 10:57 PM
Breaker Tripping Jeridmar6 Electrical 15 07-10-2010 09:20 PM
Breaker problem jdhar Electrical 11 06-10-2009 02:18 AM
