Is This Connected Correctly? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-30-2011, 07:59 PM   #1
Rewards Points: 260
Is this connected correctly?
I currently do not have power in my garage although it was wired at one time. Can anyone tell if this is connected correctly (see photo)? The line on the left is coming from the garage floor (line in) and the line on the right goes up the wall to a motion light. Then there is a line coming from the motion light running up the ceiling to a box at the crown of the roof. It then splits off 3 ways from the box. One to each wall, which go to light sockets, and the third breaks off to the other side of the garage for another motion light.
What do you guys recommend? I currently do not have a tester, but the fuse is on, on the garage circuit at the panel in my basement. Thanks!
Jesse
jpearson311 is offline   Reply With Quote
Old 10-30-2011, 08:11 PM   #2
Master Electrician
Rewards Points: 3,760
You are kidding, right?
brric is offline   Reply With Quote
The Following User Says Thank You to brric For This Useful Post:
gregzoll (10-30-2011)
Old 10-30-2011, 08:16 PM   #3
Electrician
SD515's Avatar
Rewards Points: 504
Can’t tell much of anything with that picture, the switch is in the way. The only thing I can tell is that there isn’t a connector on the right hand cable where it enters the box.
What are we supposed to recommend?
Kyle
Old 10-30-2011, 08:21 PM   #4
Rewards Points: 6,652
Jesse
For all we know, that is the mystical History Eraser Switch.
Old 10-30-2011, 08:25 PM   #5
Rewards Points: 260
Look at these pictures. Does it look like it's connected correctly?
Jesse
Is this connected correctly?-garage_light_switch-001.jpg   Is this connected correctly?-garage_light_switch-002.jpg   Is this connected correctly?-garage_light_switch-003.jpg
Old 10-30-2011, 08:34 PM   #6
Jesse
Nope, wait a minute. Nope, lost it in the fog on my crystal ball. Maybe if you flip it, it may work, it may not. Beware, due to it will transport you back in time.
I do love posts like these, because it passes time on a slow Sunday Evening. jpearson311, when you get around to finding out where the other end of that goes, so you can find out, that it will be cheaper to rip out that 1930's/1940's era wiring and update with newer and safer wiring, we will all be here to hear your plans, and hopefully you will show us all proper wiring diagrams of what you want to do, vs. pictures of lets find Waldo.
Old 10-30-2011, 08:38 PM   #7
Electrician
SD515's Avatar
Rewards Points: 504
It appears to be a 3-way switch, and from what you said about the right hand cable, the right hand cable is the load side, so the left hand cable probably goes to another 3-way switch somewhere, and that’s where the power source cable should enter the circuit. You’ll want to find the other 3-way switch.
Greg’s suggestion of upgrading the wiring is a good idea too.
Kyle
Old 10-30-2011, 10:22 PM   #8
Rewards Points: 260
I want the power to turn on in my garage. That's all.
Old 10-30-2011, 10:50 PM   #9
Is the motion light working?
Billy_Bob is offline   Reply With Quote
Old 10-30-2011, 11:22 PM   #10
Rewards Points: 260
I just looked at the motion light and well, it's not a motion light, but rather just a two bulbed light. However, when I got up on my ladder, I noticed that there was a broken bulb end inside one of the receptacles (there are 2). I started unscrewing the broken bulb end and it sparked. Does this mean that it's hot? I put a bulb in there, but nothing happened.
Jesse
Old 10-30-2011, 11:25 PM   #11
Making progress!
Go check your circuit breaker for that. Turn it off, then back on and see if that light now works. See if the switch makes the light go on/off.
Old 10-30-2011, 11:34 PM   #12
Rewards Points: 260
Making progress!
I checked the garage circuit on the breaker box and it was on. I turned it off and then back on again, went and tested the light again, but no go. I'm stumped. I guess I could post a video of my entire garage wiring starting from the inlet. It's not really that complicated.
Jesse
Old 10-30-2011, 11:57 PM   #13
Electrician
SD515's Avatar
Rewards Points: 504
This is when a meter comes in handy to test the voltage at various points of the circuit. You can pick up one for $20 or less.
The problem could be a few different things…bad wire connection someplace, bad bulbs, bad light fixture(s), etc. You said it sparked when you changed the bulb, so I’d say there should be power at the fixture, but the neutral might have a bad connection, for example.
Kyle
Old 10-31-2011, 01:35 AM   #14
I would put two known working bulbs in that light fixture (try the bulbs somewhere else to be sure they work, then put them into that light fixture).
Next check *all* the breakers in that panel. Sometimes things are mislabeled. If a breaker is tripped, it might still look on. It would be just a little to the off direction.
Then try flipping that wall switch after you do that. See if one or both of those lights will come on.
Old 10-31-2011, 02:36 PM   #15
Rewards Points: 260
I bought this on my lunch break today and I will be testing it when I get home tonight. Hopefully there is a connection.
Jesse
Outlets connected to light switch wcpatton Electrical 11 04-27-2011 08:45 PM
Roof Leak - Asphalt Tiles Don't Overlap Correctly KennyS Roofing/Siding 6 09-23-2009 09:30 AM
Wire sizes based on actual connected load BigJimmy Electrical 7 08-21-2007 09:30 PM
Adding a chair rail to dining room which is connected to kitchen Bacardi 151 Interior Decorating 7 07-05-2007 04:31 AM
Wiring of my two-zone system not working correctly AMontemagni HVAC 3 01-27-2007 01:07 PM
