Connect UF-B Cable Totransfer Switch / Inlet Box - Electrical - DIY Chatroom Home Improvement Forum
Old 03-16-2013, 02:20 AM   #1
Connect UF-B cable totransfer switch / Inlet box
Hello,
I need to run a UF-B 6AWG cable from Reliance Q506A transfer switch in the basement to the Inlet box outside. It is about 1 1/4 '' wide.
I cannot connect directly UF-B cable to the Transfer switch, since the wire is flat and is a large diameter than the opening for the fitting on the Transfer switch.
I probably need a junction box to transition UF-B to four single wires that I can connect to a Transfer switch and Inlet box. What are the models of the Junction boxes that accept flat UF cable. Will I need any extra fittings for the junction box? What type of fittings. I wont to run single wires in the conduit from Junction Box to the transfer switch / Inlet box.
In addition, since inlet box will be outside, 40+ feet from the place where it comes out from the basement, I will need a waterproof junction box. is it exist for the UF-B cable?
I do not have an Inlet box in my hands yet. Maybe there is a chance that I can connect UF-B cale directly to it somehow.
Related question I have. is the code allows to run UF-B cable along the outside house wall about 2 to 3 feet above the ground without the conduit?
Thank you,
Regards,
Vad
Vkazman is offline   Reply With Quote
Old 03-16-2013, 05:19 AM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Why did you run UF, and secondly, just use a connector that will accept UF.
Old 03-16-2013, 08:00 AM   #3
Rewards Points: 196
As far as I know you would need to run that wire in conduit above grade. Dont hold me to this but I have read that uf-b doesnt need to be ran in conduit as long as its buried 24" (might even be 18").
Jason34 is offline   Reply With Quote
Old 03-16-2013, 08:02 AM   #4
E2 Electrician
It doesn't need to be in conduit if run along a structure.
Old 03-16-2013, 09:34 AM   #5
I already bought an UF-B. I do not have a choice here. I would appreciate if somebody could send a link to the junction box that would accept UF cable.
Since I see different opinions, where can I double check whether UF can be run along the structure? Is this a state / county specific? I also have a concern about strong sunlight that the last 5 ' of cable will be exposed to.
Thank you,
Vad
Old 03-16-2013, 09:43 AM   #6
E2 Electrician
Thank you,
Vad
UF is sunlight resistant, read the jacket... and its in the NEC that it can be exposed. I still dont know why you want a jbox for the UF, just terminate it like any other cable.
Old 03-16-2013, 09:59 AM   #7
Rewards Points: 196
You should have a knockout big enough to accept a clamp connector that your wire will fit through
Old 03-16-2013, 01:56 PM   #8
A knockout in my transfer switch is 1'' round, My UF-B cable is flat and 1 1/4 inch wide.
Should I somehow widen the knockout hole? Can somebody send me a link to what type of fitting accept UF cable.
Thank you
Old 03-17-2013, 02:55 PM   #9
Semi-Pro Electro-Geek
Rewards Points: 2,990
You need to make a larger hole, to fit an appropriate cable clamp.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
flexible stranded cable for generator inlet rob613 Electrical 9 03-12-2013 08:57 PM
Custom wiring a generator to a transfer switch robojoe_fl Electrical 4 06-08-2011 12:36 AM
can switch work for two different outlets? jlmran Electrical 8 02-10-2011 12:31 PM
Re-route dryer electric cable Stu27 Electrical 10 09-06-2010 08:21 PM
fault in old bx 2 wire cable switch loop scire Electrical 1 10-25-2009 01:16 PM
