Connect A Pull Chain Switch To A Click Switch On Pendant Light. - Electrical - DIY Chatroom Home Improvement Forum
Old 02-15-2012, 12:04 AM   #1
connect a pull chain switch to a click switch on pendant light.
I have a wall switch that controls two fans and a pendant light. The circuit runs from the switch to the first fan, then through the pendant, then to the second fan. The pendant has a click switch on it. I would like to add a pull chain to the pendant (without removing the click switch), and control the light with the pull chain independently from the fans. (I want the fans to stay on when i turn the light off).
First, how do I connect the pull chain to the click switch? Second, how do I connect this pull chain/click configuration to the circuit?
davesobel is offline   Reply With Quote
Old 02-15-2012, 04:51 AM   #2
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
If the click switch has just a lock nut holding it in place you could replace it with a pull chain switch.
rrolleston is offline   Reply With Quote
Old 02-15-2012, 07:52 AM   #3
Rewards Points: 1,514
If you don't want to remove the click switch and the click switch handle cannot be activated with a string attached to it then you need to re-engineer the fixture to install a pull chain switch.
You would need to take down and perhaps dissassemble the light fixture.
A typical pull chain switch unit occupies a space about 1 inch by one inch by 1/2 inch inside the fixture. You would need to find a space inside that is not stuffed full of wires and where a hole just over 3/8 inch in diameter can be drilled through material no more than 1/8 inch thick to the outside with 1/4" side clearance all around the outside also for the switch to be mounted in.
A pull chain switch is not recommended if the fan blades are close enough that the chain could swing out or up and touch.
Ceiling Fan and Light Switch Problem desiboy Electrical 3 03-03-2011 12:09 PM
fan/light switch buzzing mjlocat Electrical 4 05-23-2010 02:44 PM
shop light conversion from pull chain to light switch gilbo Electrical 6 03-16-2010 10:49 PM
Motion Light tripping GFCI? Jonobp Electrical 5 09-07-2009 07:52 PM
Wiring from light to switch and on poorjohn Electrical 3 03-16-2009 01:23 PM
