Connect Old 2-wire Light To New 3-wire Receptacle? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-04-2012, 02:07 PM   #1
Rewards Points: 77
Connect old 2-wire light to new 3-wire receptacle?
All:
I am updating the electric in my kitchen, and subsequently a bedroom above my kitchen. I have easy access to the receptacles in the bedroom, and I plan on rewiring them with new grounded 12/2. However, the bedroom overhead light is fed from one receptacle with old 2-wire.
Is it ok by code to rewire the receptacles, but keep the old 2-wire going to the light (using a pigtail from the feeder to a receptacle)? I cannot replace the light's wiring without substantial tear-out of a nicely finished space.
Thanks.
patented is offline   Reply With Quote
Old 09-04-2012, 05:10 PM   #2
Rewards Points: 77
Anyone?
Old 09-04-2012, 06:05 PM   #3
Rewards Points: 1,442
Technically a circuit may be upgraded a little at a time with some 2 wire (ungrounded) portions remaining in service.
Technically an older 2 wire portion may not be appended to a new circuit or a circuit different from where it came.
Note that any circuit with 14 gauge portions may have a breaker no larger than 15 amps.
Two 20 amp kitchen circuits serving the counter area may not have lighting subcircuits or other rooms' receptacles hung off of them.
Old 09-04-2012, 06:11 PM   #4
Rewards Points: 77
The old wire will be on the same circuit as it was before, but fed from new feeder wire. It seems to me like this should be ok.
Do you know the code section that refers to this? I cannot seem to find it.
Thanks.
Old 09-04-2012, 06:18 PM   #5
Rewards Points: 77
Allan: just to clear up some possible confusion, the bedroom circuit is totally separate from the kitchen circuits. Its just that I have access to the bedroom circuits now that my ceiling is all torn out.
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 52 11-05-2014 05:28 PM
light receptacle vs. switch test device amakarevic Electrical 5 03-23-2012 06:15 PM
convert 3 wire range junction box to receptacle filby Electrical 0 06-05-2011 02:33 AM
Decommissioning old armored wire circuit toddmanqa Electrical 6 12-04-2009 09:55 AM
New Dryer is 3 wire, receptacle is 4 Wire. thelimit Electrical 22 01-15-2009 10:59 AM
