Old 09-06-2012, 12:36 PM   #1
Connect luminaire stranded wire leads to multiple twisted solid conductors
I am trying to minimize the # wire nuts I have in a box so as not to overfill the box (I'm in Canada so wire nuts count).
It is an octagonal box with power coming in, a line going to a switch, and two lines going to two other octagonal boxes with lights controlled by the same switch.
Can I connect the stranded leads of a fixture to where the other hots and neutrals are twisted together by wrapping the stranded leads around the twisted solids and capping with a wire nut? Or do I have to pigtail off a single wire for the fixture.
Right now I have 8 insulated conductors, and 4 wire nuts (hot power-->switch white marked as black, grounds, neutrals, switch-->lights hot). The wire leads of the fixture are #16 and so do not count. This is 10 conductors according to the CEC - the max allowed for the 245 ml box. If I have to pigtail off another wire, I will have to use an extra pair of wire nuts and this will overfill the box.
zubor is offline   Reply With Quote
Old 09-07-2012, 09:31 PM   #2
Rochsolid's Avatar
You're good to Connect your light to your 3 wire joint, no need for pigtails
Rochsolid is offline   Reply With Quote
Old 09-07-2012, 09:42 PM   #3
Licensed electrician
Check a box fill chart in the CEC. Under the NEC the box is overfilled if 1 1/2" deep.
Terminating stranded wire hammerlane Electrical 1 12-29-2011 11:13 AM
ceiling fan wicked97 Electrical 4 08-21-2011 09:12 AM
Connect a 2 wire grounded out let to a 2 wire ungrounded wire cable FranH70 Electrical 2 04-25-2011 01:59 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
Stranded wire on screw connections BigJimmy Electrical 7 01-19-2008 03:42 PM
