Connect A 14-2 To A 10-2 - Electrical - DIY Chatroom Home Improvement Forum
Old 10-16-2012, 08:33 PM   #1
Connect a 14-2 to a 10-2
The gauges are so different. Should I solder them together or twist them together and cap them
Ncs0816 is offline   Reply With Quote
Old 10-16-2012, 09:06 PM   #2
If either was done you would limit yourself to a 15 amp breaker from using 14-2. 10-2 is usually on a 30 amp breaker and a fire hazard would result if 14-2 connected to it.
drwheels is offline   Reply With Quote
Old 10-16-2012, 09:09 PM   #3
Electrician
Rewards Points: 780
It is possible to twist them together but not the easy job if you have never done it. Strip lots of copper and try bending the #10 around the #14.
darren is online now   Reply With Quote
Old 10-16-2012, 09:47 PM   #4
Rewards Points: 13,300
What is it your really trying to do?
I'd hate to see someone get hurt.
Old 10-16-2012, 10:08 PM   #5
I'm tring to run 100 feet of 10-2 to a new outlet at the end of my driveway. The existing outlet had a 14-2 and will be using for power
Old 10-16-2012, 10:14 PM   #6
Why 10-2? Seem a little over kill for just an outlet? What do you plan on powering?
Old 10-16-2012, 10:25 PM   #7
I'm using it. 10-2 will prevent more loss of volts. Correct?
Old 10-17-2012, 11:32 AM   #8
Sure, but the voltage drop depends on what load you have on the circuit. At only 100 feet I don't think you'd have to worry about it.
CheapCharlie is offline   Reply With Quote
Old 10-17-2012, 11:50 AM   #9
Rewards Points: 150
For a 100' run (200' total circuit length):
  • #14 = 0.505 ohms
  • #12 = 0.318 ohms
  • #10 = 0.200 ohms
  • (source)
Voltage drop, assuming a 15 Amp load (max for #14):
  • #14 = ~7.5 volts
  • #12 = ~4.8 volts
  • #10 = ~3.0 volts
Whether the 4.5 volt difference is worth the extra cost and trouble of using #10 is up to you.
Dave632 is offline   Reply With Quote
Old 10-17-2012, 12:12 PM   #10
Where are you from? If from Canada, the voltage drop is limited by code to 3% on a branch circuit.
Old 10-17-2012, 12:18 PM   #11
Electrical Contractor
jbfan's Avatar
Rewards Points: 254
It is just a recommendation in the states, not a code issue.
Old 10-17-2012, 12:31 PM   #12
That's why I posted that. Doesn't say in his profile
The Following User Says Thank You to CheapCharlie For This Useful Post:
jbfan (10-17-2012)
Old 10-17-2012, 06:36 PM   #13
  • #14 = 0.505 ohms
  • #12 = 0.318 ohms
  • #10 = 0.200 ohms
  • (source)
  • #14 = ~7.5 volts
  • #12 = ~4.8 volts
  • #10 = ~3.0 volts
Is the total length 200?
Old 10-17-2012, 06:36 PM   #14
Live in virginia
Old 10-17-2012, 06:38 PM   #15
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Just use wire nuts, align the ends and install wirenut.
How to wire a 30A 250v plug and connect it to a well pump control box diyorgobroke Electrical 3 05-21-2012 05:08 PM
Apartment- Connect portable washer straight to sink drain + double quick connect? DrDreams Plumbing 1 03-14-2012 09:30 AM
What pipe is this? can I connect abs to it? oregondiy Plumbing 3 04-04-2011 08:33 AM
Basement toilet: Watergenie - how to connect to main stack GD73 Plumbing 1 12-21-2009 11:13 AM
Adding a phone line to an older connect point cramsmith General DIY Discussions 3 11-23-2005 12:35 PM
