Confusion With Three Way Plugs / Switches - Electrical - DIY Chatroom Home Improvement Forum
Old 06-03-2011, 02:03 PM   #1
Confusion with three way plugs / switches
There is a lot of confusion on the 'net with this topic..glad I found this forum.
I have two - 3 way switches on either side of my garage. To hook up a radio, I need to run a long extention cord...i hate doing that.
If I understand what everyone has been saying...the red wire is the flippy/floppy wire that allows 3 ways to work but the black/white wire stays the same.
Would it work if I pull out the wires out of the far switch..put them into a connection box...use all three colours to run to a new light stitch in a new box and feed just the black/white to a new two outlet unit. Not sure what I would ue for ground ...
Thanks,
ian.
grassy is offline   Reply With Quote
Old 06-03-2011, 02:32 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 224
Depends on the # of wires and colors in the switch box.
Take the switch out and tell what wires are there.
jbfan is online now   Reply With Quote
Old 06-03-2011, 03:44 PM   #3
joed's Avatar
Rewards Points: 11,974
If you only have three wires in the switch box then you CAN NOT install a receptacle. There is no neutral wire in the box.
Your assumptions about the wire colours are not correct. Any of the colours could be used for any part of the circuit.
Question about wiring and voltage with switches and lights rswurth Electrical 17 06-21-2010 12:12 AM
Question about switches on a 20 amp circuit Abs777 Electrical 6 04-28-2010 11:09 AM
switches and plugs on same circuit-- how? cabinjunkie Electrical 18 08-08-2009 03:53 PM
Replacing switches turning into nightmare. RyanD Electrical 19 05-26-2009 07:19 PM
Need help replacing switches in four-way circuit magnolia Electrical 3 05-09-2008 10:40 PM
