Confusion On A Hot Wire? - Electrical - DIY Chatroom Home Improvement Forum
Old 07-08-2011, 08:04 AM   #1
Confusion on a hot wire?
I am installing a baseboard heater in a room , with a 220V line coming out of the wall. I also added a thermostat switch right to the unit of the baseboard
(not a wall mount switch) as far as the wiring goes through the thermostat switch which has 2 wires coming off it, it requires that a hot wire be connected specifically to one of the wires.
My problem is, on a standard 110v i know black is "HOT" and white is "neutral".
But this 220v line that i have has a "black" wire , "Red" wire and a ground.
so what would be considered as my "Hot" wire, The Black or the Red?
wutagoalie is offline   Reply With Quote
Old 07-08-2011, 08:20 AM   #2
Licensed electrician
Rewards Points: 1,598
Both the black and red would be hots in a 240 volt circuit.
Old 07-08-2011, 08:49 AM   #3
Thanks Jim
Old 07-08-2011, 10:54 AM   #4
joed's Avatar
Rewards Points: 12,850
Use either the black or red. You only need to switch one of them to turn it off and on.
Proper Use of Green Wire Nuts HooKooDooKu Electrical 16 06-29-2012 06:41 PM
convert 3 wire range junction box to receptacle filby Electrical 0 06-05-2011 01:33 AM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 03:30 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Stranded wire on screw connections BigJimmy Electrical 7 01-19-2008 02:42 PM
