-   -   Confusion on a hot wire? (http://www.diychatroom.com/f18/confusion-hot-wire-110037/)
wutagoalie 07-08-2011 08:04 AM
I am installing a baseboard heater in a room , with a 220V line coming out of the wall. I also added a thermostat switch right to the unit of the baseboard
(not a wall mount switch) as far as the wiring goes through the thermostat switch which has 2 wires coming off it, it requires that a hot wire be connected specifically to one of the wires.
My problem is, on a standard 110v i know black is "HOT" and white is "neutral".
But this 220v line that i have has a "black" wire , "Red" wire and a ground.
so what would be considered as my "Hot" wire, The Black or the Red?
:eek:
Jim Port 07-08-2011 08:20 AM
Both the black and red would be hots in a 240 volt circuit.
wutagoalie 07-08-2011 08:49 AM
Thanks Jim
joed 07-08-2011 10:54 AM
Use either the black or red. You only need to switch one of them to turn it off and on.
