Confused By Steam Shower Power - Electrical - DIY Chatroom Home Improvement Forum
Old 11-04-2012, 11:14 AM   #1
Confused by Steam Shower Power
I am installing an Ariel Steam shower DZ962F8 that has a 6KW generator at 240V, 30 amps. However the wiring diagram shows 1 black, 1 white and 1 ground. Shouldn't I need black, red, white and ground?
I haven't ordered it yet but need to run the wire and don't know if I should run 10/2 or 10/3.
Any ideas
ockham is offline   Reply With Quote
Old 11-04-2012, 12:05 PM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Any ideas
10-2 is sufficient.
The Following User Says Thank You to stickboy1375 For This Useful Post:
ockham (11-04-2012)
Old 11-04-2012, 12:05 PM   #3
Master Electrician
Rewards Points: 3,960
10-2w/grd. No neutral required. A 10-2 w/grd will give you a black Line 1 and a white Line 2 which is what the instruction manual indicates.
brric is offline   Reply With Quote
The Following User Says Thank You to brric For This Useful Post:
ockham (11-04-2012)
Old 11-04-2012, 12:47 PM   #4
Licensed electrician
Rewards Points: 1,872
You will re-identify the white as a hot conductor with tape or magic marker.
Old 11-04-2012, 01:27 PM   #5
That is what I was missing
Old 11-04-2012, 01:28 PM   #6
E2 Electrician
If you don't put tape around the white conductor it won't work.
Old 11-04-2012, 02:02 PM   #7
Master Electrician
How true.
Old 11-04-2012, 04:56 PM   #8
We know how that will become an issue if someone every decides to sell the home.
Old 11-04-2012, 05:23 PM   #9
Master Electrician
Thanks to overzealous home inspectors.
stickboy1375 (11-04-2012)
Old 11-04-2012, 05:27 PM   #10
Electrician
Rewards Points: 802
Yes those electrons are very picky to what colour of wire they take a ride on.
darren is offline   Reply With Quote
The Following User Says Thank You to darren For This Useful Post:
Old 11-04-2012, 09:54 PM   #11
" Euro " electrician
frenchelectrican's Avatar
Yeah but use the tape to choke the netural to build up the "pressure " where what we need to be run.
Merci,
Marc
Old 11-05-2012, 05:58 AM   #12
E2 Electrician
I meant my comment as pure comic relief.
lack of visible vapor in steam shower installation CasaSemanas Plumbing 23 06-14-2017 03:05 PM
Event Production power distribution, I want to do it right. mattvivsound Electrical 0 07-13-2012 08:54 AM
Steam Shower txcarrie Remodeling 0 03-28-2012 12:24 PM
steam shower jarfly Plumbing 4 02-11-2010 12:16 PM
Steam Shower glass enclosure help christy123 Building & Construction 1 04-11-2009 06:17 AM
