Confused On Adding A Timed Light Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 03-20-2017, 12:29 PM   #1
Rewards Points: 34
confused on adding a timed light switch
Hi all! So, im changing up some light switches to timed switches. I was doing fine until i ran into a box with 3 wires and the other 2 wires (white/neutrals were tied into 1)
so this switch has the 2 blacks the 1 red and 1 ground connected
the light switch i ordered has 2 blacks (like a basic toggle switch) I am not sure why one of the cable has a red load if there is no 3 way switch.
The other toggles were fine since i just connected the 2 blacks/hot and the ground.
can I just wire the red and black into one cable onto the light switch?
it looked something like this, sorry for the bad drawing. i can take a picture when i get back to work
willchap86 is offline   Reply With Quote
Old 03-20-2017, 12:35 PM   #2
joed's Avatar
Rewards Points: 12,388
Re: confused on adding a timed light switch
The other switch had two screws? There were wires connected to those two screws.
Connect the new switch the same way.
Old 03-20-2017, 12:45 PM   #3
Rewards Points: 34
thanks for the reply
so sadly, the new (timed switch) has only 2 black cables
the switch im trying to replace has 2 blacks, and a red...i have no clue why that red is there since it is not a 3 way switch ha ha.
Old 03-20-2017, 01:20 PM   #4
Licensed electrician
Rewards Points: 1,478
A red doesn't always mean a 3 way. It is just another color for a hot. You might have had power in, power out and and switched red . We're the two blacks on the same end of the old switch?
Old 03-20-2017, 01:48 PM   #5
joed's Avatar
If the old switch only had two terminals then two of the wires must have been connected to one terminal. Do the same thing with the new timer. Connect the same two wires to one of the timer connections and the third wire to the other one.
Old 03-20-2017, 04:24 PM   #6
Rewards Points: 34
ill take a picture when I get home.
but the old switch has 4 terminals..
so the black and red were on the bottom of the switch
and there was another black from the different cable on top of the switch
http://i.imgur.com/dGOXXlE.png
this is the diagram..looks bad sorry
Old 03-20-2017, 04:57 PM   #7
Rewards Points: 1,568
Does the existing switch have on and off stamped on it?
John Grabowski
MrElectrician.TV
MrElectricianTV is offline   Reply With Quote
Old 03-20-2017, 05:44 PM   #8
Rewards Points: 34
No on and off lettering anywhere. I can problalby move the black and red to the top and the other black to the bottom and will still shut on and off.
the little switch thingy is plain with no lettering.
I might just have to get an actual timed outlet vs the spring loaded timed switch. I just really like the spring loaded one since i can just turn it and not force to have a selection (my own weird ways haha)
the actual timed outlet has the normal 4 cabled. hot load neutral and ground,
but the one I would like to use is just 2 blacks. (equivalent to a normal 2 screw light switch)
Old 03-20-2017, 06:03 PM   #9
Rewards Points: 34
so i have a better representation now
Im used to seeing light switches with 2 hots (black)
so the switch I have connects to those 2 blacks
but the problem is that switch has an red hooked up like this
so im a bit stumped now on why that red is there and how would I hook it up to the new timed switch with 2 blacks....
i hope this makes more sense. thanks for all of your help
Old 03-20-2017, 06:09 PM   #10
A three way switch needs three wires. You are going to need a different switch.
Old 03-20-2017, 06:13 PM   #11
Rewards Points: 34
thats the weird part...its not a 3 way switch. theres only 1 switch that controls that light. thats the part im confused about.
Old 03-20-2017, 06:21 PM   #12
joed's Avatar
If there are three separate screws on that switch it is a three way switch.
We can't see the important side. Could it be that one wire is under the screw and the other is poked into the hole in the back? If true then consider those two wires to be on the same screw and connect them together.
Old 03-20-2017, 06:31 PM   #13
Rewards Points: 34
thank you!! ill take a picture of the back side soon.
so its safe to twist the red and black together on the black cable to new switch?
Old 03-20-2017, 06:47 PM   #14
joed's Avatar
No. The red is definitely separate. It looks like the two black might be together and the red on the other terminal.
Old 03-20-2017, 07:30 PM   #15
Rewards Points: 34
ok got a sample diagram. so this is exactly how its hooked up.
So i should tie the 2 blacks together to the other black on the timed switch and the red on the other black correct?
Switch loop - adding light fixture kcoons83 Electrical 5 02-08-2016 06:28 AM
Adding a Second Light to a Double Switch hsclucas15 Electrical 1 01-07-2016 11:03 PM
Adding 2nd light to 4 way switch. Lights are reversed. coolguybob Electrical 11 11-03-2015 11:30 PM
Diagram for 3 way ceiling fan light switch Aurora65 Electrical 22 11-27-2012 09:11 AM
Hot wires on both sides of switch RedRumLoki Electrical 4 11-20-2012 09:37 PM
