Confused About Grounding. - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 11-09-2008, 10:43 PM   #31
Electrician
Originally Posted by Stubbie View Post
Not allowed, within the city limits for single family dwelling.
So what if the main breaker panel cannot be placed directly inside the structure? Still no go? I'm referring to 230.70 (A)(1) BTW.
chris75 is offline   Reply With Quote
Old 11-09-2008, 10:53 PM   #32
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Yes that would be allowed, I was speaking to a single service disconnect remote from the panel. Meter mains and main breaker panels on an outside wall are fine.... If it is new construction it must be on the side (not rear) of the house nearest the service source.
Old 11-09-2008, 11:08 PM   #33
Electrician
I have to ask, whats the reasoning behind not allowing a disconnect after the meter and before the panel?
Many a jobs I've installed a disconnect right after entering the structure, then locate the panel elsewhere in the building.
Old 11-09-2008, 11:21 PM   #34
UAW SKILLED TRADES
Stubbie's Avatar
You know I've never been given a understandable reason and for what it is worth that is exactly what I would prefer... so I could isolate the panel. Codes tells us that KC Power and light started this requirement in the 60's. So it's a utility thing but I can't give you the exact reason as I've been told several over the years. When you think about it there isn't a good reason.
Old 11-10-2008, 12:26 AM   #35
Rewards Points: 2,350
Wait. Are you saying that the poco wouldn't allow you to, say, place a meter socket, then poke through the structure into a disconnect? That's quite odd. I myself don't like the idea of un-fused service conductors running dozens of feet inside a structure. I'm even a little weary of back-to-back installs. I like my disconnects on the outside of the building. Maybe I'm the oddball...
Old 11-10-2008, 12:44 AM   #36
UAW SKILLED TRADES
Stubbie's Avatar
No you can have a disconnect inside but it must be in the form of a main breaker panel not an isolating ocpd. But it has been a 4 years for me working in that part of town. I just copied the latest requirements off the Kcpl site they now do not allow meter mains at all but I'm not finding anything anymore about disallowing service disconnects before the panel.
Check out how close they want the water pipe bond.
They do have appeal provisions for exceptions but it is very rare to see any outside disconnects or panels on single family construction over the last 40 years in this area of Kansas unless you get to rural jurisdictions. 9 out of 10 homes have the meter outside and then immediately inside is a main breaker panel.
Old 11-10-2008, 01:13 AM   #37
I read the words, and I understand them. But that makes no sense as to why. What could possibly be wrong with an isolating switch, or outside disconnect. I can't see how a disco on the outside wouldn't be a plus. How strange...
Old 11-10-2008, 01:17 AM   #38
DIYer
What about those setups with the main breakers in the meter box? Could you use one of those instead of a disconnect?
Gigs is offline   Reply With Quote
Old 11-10-2008, 01:47 AM   #39
UAW SKILLED TRADES
Stubbie's Avatar
Read the last sentence of the copied section in previous post
Old 11-10-2008, 04:43 PM   #40
Electrician
That queston was already asked and answered.
Old 11-10-2008, 08:48 PM   #41
DIYer
Sorry, I failed at reading comprehension.
Old 11-10-2008, 08:50 PM   #42
Electrician
Dont worry, your not alone...
Tags
ground , neutral
Grounding light box n0c7 Electrical 10 10-06-2008 04:20 PM
Sub-panel grounding question. gesoneguy Electrical 31 02-22-2008 09:25 AM
Grounding electrode at subpanel Randell Tarin Electrical 18 02-01-2008 10:05 PM
NEC Question Jafsvcs Electrical 1 06-13-2007 06:45 PM
Toggle switches: With or without grounding screw? Marekus Electrical 3 11-27-2006 04:48 PM
