Old 06-23-2011, 08:03 PM   #1
rookie
Neko's Avatar
Conflicting information
I have my meter on the side of a detached garage which contains two fuses each 100amps both of these including a neutral that is connected to an underground earth ground. The meter box itself is bonded with a screw to the ground. Three wires enter the detached home(75ft away). My question is do I need to have a earth or water pipe ground in the sub panel inside the home?
So I need to install a ground in sub panel located inside home?
Neko is offline   Reply With Quote
Old 06-23-2011, 08:15 PM   #2
Electrician
SD515's Avatar
From the description, yes, a ground rod (probably 2 actually), and the metal water piping bonded also.
Kyle
Old 06-23-2011, 08:42 PM   #3
rookie
Neko's Avatar
What I'm doing is replacing the sub panel inside the home with a newer plus bigger panel box. My grand father built this home in the late 1940's. 3 wires feed to the panel located in the home. Do I need to use the green grounding screw included with the new panel box located in the home?
Old 06-23-2011, 11:30 PM   #4
Lic Electrical Inspector
electures's Avatar
Where is the main breaker?
All responses based on the 2011 NEC.
If you live in New Jersey click
. All other states click
Please check with local, county and state officials as laws may vary.
Sizing motors
. Online motor calculator
. Online calculators
electures is offline   Reply With Quote
I need information that I'm going to have to present to a County Commision BJLower Off Topic 1 03-31-2010 08:58 AM
Please Help on Exteriror Paint Job - Getting conflicting information Omniver Painting 16 06-10-2009 03:54 PM
You too can buy an AFCI breaker for $1000! Gigs Electrical 19 02-09-2009 04:13 PM
