Conflicting Info On Using 10-3 - Electrical - DIY Chatroom Home Improvement Forum
Old 07-25-2009, 08:48 AM   #1
We pick these?
Conflicting info on using 10-3
My electrical official at the compliance office suggested that I can use the existing 10-3+ ground dryer homerun to satisfy requirement for (2) dedicated 20A GFCI circuits in my laundry area. He said I need to share the neutral. The info I've seen disagrees whether to use separate 120v 20A breakers in the box or to maintain a 240v 20A double-pole breaker. There is a junction box in the bathroom where I will obviously need to pigtail the neutral wire of the 10-3 to both the 12-2 wires. Can someone advise me how to do this in a residential situation? BTW, we are using NG for the dryer, the 10-3 has been unused for 15 years but is intact with a 30A double-pole breaker.
NailedIt is offline   Reply With Quote
Old 07-25-2009, 08:54 AM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,948
Under the 2008 NEC you must use a 2-pole breaker.
Although not always mandatory, in any case it is a good idea.
Old 07-25-2009, 09:07 AM   #3
Yes, you would need to replace the 30a double pole with a 20a double pole
I'm aware of the requirement for a single dedicated laundry circuit
Why is he asking for a 2nd circuit?
You mention a laundry area then talk about a bathroom?
Are you running one circuit to the laundry area & one to the bathroom?
One 12-2 goes to one area, black to black, white to white, ground to ground
2nd 12-2 to other area, black to RED, white to white, ground to ground
Bathroom must be GFCI protected
Laundry outlet if within 6' of a sink must be GFCI
Old 07-25-2009, 09:29 AM   #4
We pick these?
thanks for speedy responses
I've divided the old "large" laundry room and "miniscule" powder room into a full bath for the new master suite and a combination powder room/ laundry room (laundry equipment in 3x5 closet). I have the GFCI's covered already for the bathroom requirement and was aware of the requirement for the washing machine. The official said I also need a dedicated GFCI for the dryer. I am operating under a homeowner self-permit. In short, I don't know "all" about electrical codes, etc... I'm assuming he's told me what he wants to see, as far as a dedicated GFCI for both washer and dryer. There is (1) 20A 120V single pole home-run circuit to supply (2) GFCI in the back to back bathrooms, and the 10-3 will supply the washer/dryer split into (2) GFCI's, at least that's what my E.I. suggested and I'm taking his advice as something that will get me a green-tag.
Old 07-25-2009, 11:02 AM   #5
A laundry area does require a dedicated circuit & that circuit can't leave the laundry area.
If the laundry area is now in a 3x5 closet then the circuit can't leave that closet
Dryer you stated is gas, so you need a 120v connection
The dedicated circuit can feed both the washer & dryer
There isn't anything that indicates a need for 2 circuits
Unless it is a local requirement
OR
The washer takes up a lot of power
But in the end you need to do what makes the Inspector happy
Old 07-25-2009, 12:51 PM   #6
What they said....plus
Make sure the 10/12/12 neutral connection is bulletproof. Lose the neutral there and you will damage some equipment.
220/221 is offline   Reply With Quote
Old 07-25-2009, 10:23 PM   #7
We pick these?
Makes inspector happy, I'm happy
It may be local code in Indianapolis to have (2) dedicated circuits for laundry, or it may be my own special requirement, I don't really know. I didn't think it made sense to require a dedicated circuit for the dryer, but it's not a big deal with the wiring already there. I have plenty of home-runs: (1) for smokes, (3) separate GFCI's in the bathrooms and laundry, and still have (3) circuits for the bedroom, study, and sitting room.
Thanks for the assistance, folks.
Before I forget. One of the 20A circuits is a double-pole with 12-2 wire. Can I move the white wire to the neutral bus and leave the double breaker in place, rather than purchase a single pole breaker and blank? The other 4 circuits are all 20A single pole breakers with 12-2.
Old 07-26-2009, 08:39 PM   #8
Electrical Contractor
jbfan's Avatar
Rewards Points: 420
Yes. We may get called a hack for doing it that way, but it can be done.
Old 07-27-2009, 06:41 PM   #9
We pick these?
Hack, me?
maybe so...
GE Motor cross ref info kcsimcoe Electrical 5 07-07-2009 11:36 AM
Need some Carrier Info Home Air Direct HVAC 0 06-18-2009 09:48 AM
Help! Conflicting info on sub panel feeder robertmee Electrical 15 06-02-2009 04:07 PM
Conflicting Circuit Info!?? BenBil Electrical 9 01-15-2007 08:26 AM
