Confirming Light Switch Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 12-08-2007, 05:01 AM   #1
Confirming light switch wiring
Hi all,
I am upgrading a Tenby lightswitch to a Marbo dimmer single 2way 400W and would like confirmation of how to wire up the new dimmer. The light is 3x60W (dimmable) so the 400W is certainly within spec.
reverse view of existing light switch
Reverse view of new dimmer
Please can you confirm what goes where?
Chris_Von_Bron is offline   Reply With Quote
Old 12-08-2007, 07:48 AM   #2
Licensed Pro
If you are in the UK, and I suspect you are, please note that in your post. This site is monitored predominately by US electricians and DIYers.
Old 12-08-2007, 01:35 PM   #3
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
The far right with the ac symbol and arrow is your common and the others (L1 L2) is the 'dimmed' hots going to the lights. Your old switch is labeled 1 and 2 and common. Take the 2 reds out of 1(old switch) and put them in L1 (dimmer)and the common(old) in the hole with the arrow symbol (dimmer). L2 is not used. You have a ceiling rose most likely so if you make changes at the light fixtures keep track of where your wires connect. Also new code is brown for hot wires so the old red ones are supposed to have little brown sleeves put on them....red is the old live color. I am assuming these sleeves a readily available at the electrical house. Your voltage is 240 volts to neutral so make freakin sure you arent powered when you work on this. The 2 blacks connected are your neutral and the green yellow is your earth.
Just to add the L2 is for two way or what we call in the US a 3 way circuit. So L1 and L2 would be utilized in your 2 way situations. In the US we call these the travelers to the other switch.
good Luck
Old 12-08-2007, 07:33 PM   #4
Sorry, I forgot to mention that I am in the UK. Thanks for the comprehensive reply. I will have the deepen the recess so that the deeper dimmer will fit, but I have test wired the dimmer and it works perfectly. Many thanks for the guidance!
Old 12-08-2007, 07:42 PM   #5
UAW SKILLED TRADES
Stubbie's Avatar
You're welcome Chris... we have the same issues with too shallow of a recess in the US at times.
Wiring double switch for new ceiling fan toolmanwannabe Electrical 17 11-15-2011 10:34 PM
3-Way Switch Wiring Question bhpizza Electrical 4 08-07-2007 06:51 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
Ceiling Fixture / Switch Wiring gregger Electrical 1 10-21-2006 08:47 PM
Wiring a light with switch....please help!! lindo1951 Electrical 19 10-16-2006 03:32 PM
