Confirming Circuit Load Test - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-22-2011, 01:44 PM   #16
Originally Posted by jbfan View Post
Depending on make and model of the panel, tandem breakers could be an option.
Give us the brand and model number, and someone will tell you.
OK...I know it's a GE model. It appears to be original and the house was constructed in 1978. I couldn't find a model number but I'll look again and snap a pic.
chewbakarox is offline   Reply With Quote
Old 09-22-2011, 03:28 PM   #17
OK, so here are the pics. I couldn't find a model number anywhere, but there is a big "General Electric" stamp on the outer cover (not shown). Unfortunately, most of the paper label on the breaker has been torn off, but I took a pic of what was left. Any guesses on what type/model of breaker this is?
Confirming Circuit Load Test-cover.jpg   Confirming Circuit Load Test-no-cover.jpg   Confirming Circuit Load Test-label.jpg
Old 09-22-2011, 11:40 PM   #18
" Euro " electrician
frenchelectrican's Avatar
Ah., Oui .,,
That is THQP breaker set up and they do come in both single and two pole verison { but pay attetion if you go with two pole verison make sure you have landed between two bussbar if not you will not get any 240 volts load at all }
The only two issue I know for sure one is you may have some pretty tough time to bring new cable in all in one box and second thing that you have 100 amp main breaker IMO you are pretty close to boarderline on loadwise { I do not know what sq footage or sq meter your house space is at the moment so you may have to do the load demand caluaction to see how much room to work around.
Merci,
Marc
Old 09-23-2011, 04:27 PM   #19
Originally Posted by frenchelectrican View Post
Ah., Oui .,,
Merci,
Marc
Thank you Marc. My house is about 1,900 SF. Here are some follow up questions that I have:
1) I assume my panel is full since there is no room beneath the main breaker. There looks to be some room above the main breaker. Can someone confirm whether or not these are "slots" that I can use for a new circuit?
2) Assuming I am out of room....what are my options? Adding a subpanel? "Tandem breakers" as someone suggested?
Old 09-23-2011, 08:27 PM   #20
Electrical Contractor
jbfan's Avatar
Rewards Points: 534
It appears that you can add breakers above the main.
LikeMarc said, it will be hard to get the new wires into the panel.
The Following User Says Thank You to jbfan For This Useful Post:
frenchelectrican (09-23-2011)
Dispute: Oven malfunction after h/w guys used the circuit rational Appliances 18 05-17-2011 10:37 PM
Fridge/Disposal on same Circuit Atskodinski Electrical 6 01-07-2011 07:38 PM
How to wire three switches on one circuit Abs777 Electrical 12 03-25-2010 03:15 PM
Open circuit has power, close the circuit no power??? BeginnerHomeDIY Electrical 7 07-08-2009 02:40 PM
Problem with circuit breaker. HELP! spartanic Electrical 2 10-28-2007 03:09 PM
