Confirmation Of Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 10-14-2010, 12:20 AM   #1
Rewards Points: 28
Confirmation of wiring
Just looking for some confirmation along with an answer to a question.
I've wired a circuit in the following order:
1. Panel
2. Light box (ceiling) Supply + 3 x 14/2 wires
3. Wire 1 - goes to switch (for the light at this electrical box)
4. Wire 2 - goes to outlets (3)
5. Wire 3 - goes to another outlet/light
I've attached a diagram to make it a bit easier. Could someone please confirm that it is correct?
Question: Does it matter at the switch whether the white is on the top screw or the bottom screw?
jim.thornton is offline   Reply With Quote
Old 10-14-2010, 12:24 AM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
make sure you remark the white wire used as the switch leg as a hot wire.
the other light has it's own switch, right?
on the switch; doesn't matter which screw the hot/switchleg is attached to.
Old 10-14-2010, 01:32 AM   #3
Mad Scientist
I may be wrong, because I get this mixed up sometimes; but I think you need one small change:
At the junction box in the middle of your picture, the two wires from the cable labeled "Switch" should be swapped. The white (marked black/red/whatever) should be the constant feed to the switch, and the black should be the switched power from the switch.
I don't believe I know the reason for this, but there you have it.
McSteve is offline   Reply With Quote
Old 10-14-2010, 05:52 AM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
This is 100% correct.
Old 10-14-2010, 08:01 AM   #5
Rewards Points: 28
Thank you and I will change it as suggested.
Is this a safety issue or is it a consistency issue?
Old 10-14-2010, 08:04 AM   #6
Rewards Points: 28
I have marked the wired by covering it in electrical tape (I didn't have black so I used green).
In addition, the other light has it's own switch, I'm just labeling it to make it easier to understand what I've done. That is the supply line for the next light.
Old 10-14-2010, 08:04 AM   #7
I=E/R
a7ecorsair's Avatar
If I open up a junction box and find a white wire nutted to three black wires I would know it is a switch leg.
a7ecorsair is offline   Reply With Quote
Old 10-14-2010, 08:46 AM   #8
Electrical Contractor
jbfan's Avatar
Rewards Points: 490
Green is not acceptable.
Use a black marker.
Old 10-14-2010, 11:38 AM   #9
Absolutely DO NOT use green!
Old 10-14-2010, 11:55 AM   #10
Rewards Points: 28
Okay... I will change it all to black.
Curious: What is the problem with green. I figured it was okay because it was still electrical tape.
Old 10-14-2010, 11:56 AM   #11
Mad Scientist
The NEC reserves green for grounding conductors.
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 07:53 AM
Cloth Wiring - Replace? JessicaGus Electrical 9 09-23-2009 06:45 PM
electric wiring in house remodel wis_remod Electrical 6 04-02-2009 02:40 PM
New Home Wiring - Seeking Expert Advice Dirtrnr Electrical 3 02-10-2009 10:33 AM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
