Configuration For Recessed Lighting In Small Room - Electrical - DIY Chatroom Home Improvement Forum
Old 06-06-2013, 08:26 PM   #1
Rewards Points: 178
configuration for recessed lighting in small room
The room is roughly 11 feet x 8 feet. The ceiling is low at 6 feet 6 inches. A desk will sit at one end of the room and a futon will sit at the other. This room will function as a home office and small guest room. What size recessed lighting should I get, how many and where should they be placed/laid out?
Also, heat is a concern since the ceiling is low so anything that puts out the least amount of heat is preferred (not sure if that affects light size and/or layout).
anuvanoob is offline   Reply With Quote
Old 06-07-2013, 09:12 AM   #2
JW
mm11's Avatar
Rewards Points: 614
I would use four 6" cans with CFL lamps, spaced equally from the walls.
mm11 is offline   Reply With Quote
Old 06-08-2013, 11:46 AM   #3
Rewards Points: 178
4? Really? I just heard the rule of thumb was 120 watt per 100 square feet. Given that the lights are at least 60 watts each your suggestion would be 240 watt for this 88 feet. Is that overkill?
Old 06-08-2013, 12:05 PM   #4
MarginallyQualified
Rewards Points: 2,464
At 6'6" I wouldn't used recessed cans at all.
Nor any other center of the room sort of ceiling fixture.
Think valance at the ceiling/wall edge... and table/desk/task lamps. LINK
The Following User Says Thank You to TarheelTerp For This Useful Post:
Philly Master (06-08-2013)
Old 06-08-2013, 01:22 PM   #5
Oso954's Avatar
Rewards Points: 1,132
I would toss any "rule" about watts per square feet.
You need to look at the number of lumens that are effectively delivered to the area. A 65 watt flood will put more light where you need it, than a 100 watt A19.
As far as 60 watts per can in your math, R30 bulbs are made as 45 watts and 45 watt equivalents.
Dimmers are also great for controlling the amount of light.
4 cans with lower wattage bulbs and/or dimming will give you a much more even light in the room, than 2 cans with higher power bulbs. That is particularly true with your very low ceiling.
Oso954 is offline   Reply With Quote
Old 06-08-2013, 02:55 PM   #6
Resi EC
Rewards Points: 252
One way I was told, however high your ceiling is, is how much spread you'll get.
6'6" ceiling 6'6" spread of good light on the floor using recessed lighting.
Again thats just what I've heard.
there are exceptions to every 'rule of thumb'
Taller ceiling require more just because of distance to the floor.
Gac66610 is offline   Reply With Quote
Old 06-10-2013, 12:12 PM   #7
Rewards Points: 178
I ended up installing two 6 inch 12.5 (65) watts LED recessed lights roughly 32 inches from the wall which made them 5 feet and 6 inches apart. I'll let ya know how well or how poorly the room is lit (still gotta tape, mud, prime, paint and finish up electrical).
Old 06-10-2013, 12:43 PM   #8
Resi EC
Rewards Points: 252
Guess I should have said that I would put 4 in, it's easier to install a LED dimmer later, than it is to add more recessed cans
Just my opinion
The Following User Says Thank You to Gac66610 For This Useful Post:
mm11 (06-10-2013)
Old 06-10-2013, 03:38 PM   #9
Rewards Points: 178
Just my opinion
Ha! Good point!
Lighting placement for kitchen/living room? I'm no BobVilla Electrical 5 04-18-2013 08:14 AM
should i turn my dining room into a dining kitchen heathpw Building & Construction 4 04-10-2013 07:08 PM
Bedroom receptacles room lighting on same circuit Clutchcargo Electrical 2 02-08-2012 02:39 PM
family room lighting debd Remodeling 4 11-15-2010 11:14 AM
Laying carpet for small exercise room J187 Flooring 10 09-30-2007 08:28 PM
