Configuration Needed With Safety And Code In Mind - Electrical - DIY Chatroom Home Improvement Forum
Old 08-24-2012, 03:06 PM   #1
Configuration needed with safety and code in mind
???????How would you suggest I divide the following items up from -1- 20amp aluminum circuit to -3- new 20amp copper circuits?????? I am running 12/2.
...3 GFI outlets for counter (used once in a while),
...Fridge (outlet but not counter)
...Dishwasher...outlet or hardware have not decided.
...Gasstove /the ignitor and display (outlet but not counter)
...1 exhuast fan to the outside.
...1 hood/light fan (will probably eliminate)
....no Microwave yet but if so where? I could swap it out with the hood fan.
I am also putting the bathroom outlet on it's own circuit (new copper).
Please read the background info.
The Subpanel is a 40 pushmatic the service can not be upgraded, 8 AWG.
I am under the impression that pushmatic are good panels since its breakers get bolted to the bus but if the breakers need to be replaced they are expenive. I don't care for it and would upgrade.
This is the setup of the panel now, I guess it is impt to know that they pole from left to right and split up and down, if that makes sense. I note which are full and split. It has 6 spaces.
30 amp..AC)............. 30 amp (Blower)....(Two Phase for the Hvac -furnace/ AC)
full slot.......................... full slot
20amp..(Kitchen)....... 15 amp split...(Bathroom & bedroom)
full ..........................15 amp split... (Living room)
15amp (dinRm).....20amp split open
full ....................?amp open GFI
I will replace the 20 amp kitchen breaker with a split 20 amp (X2)
and the open breaker on the bottom right will also be a 20amp split (X2).
So that is a total of 3 new circuits and a replacement of one that exists. replacing Two breakers and adding Two.
Jzone99 is offline   Reply With Quote
Old 08-24-2012, 06:10 PM   #2
Rewards Points: 6,652
Are you crazy, do you want to start an argument? Do a search on this topic regarding Kitchen circuits, and every one of them becomes a huge bicker fest back and forth, how to do it better.
As for doing it correctly, first start by either making a phone call to your local city permit office, or search their website. Then suggest getting together with a local Sparky and having them do a walk through with what you have now, sit down over a beer or two with you, and plan out the changes.
As for how I would do it, figure what you have going into the space, that is not there already, and then go from there. If you only have two counters splitting the Kitchen sink, you can feed one 20 amp circuit per counter, and also can feed the baseboard outlets with those two outlets. Now of course you can in some places get away with putting the spark/clock for a gas stove on one of the 20 amp circuits, same as the stove.
Disposall & Dish washer, some places you can put both on a 20 amp circuit, but now you have to keep them on separate circuits.
Again, put it down on paper, make some phone calls, find a Sparky to invite over for a beer or two, and go through the plans. As long as you are going from Aluminum to Copper, you will be in good shape. The bad part gets going, is when people try to "fix" an aluminum circuit, without doing it right.
Old 08-24-2012, 06:31 PM   #3
Licensed electrician
Rewards Points: 1,766
These seem to be the same questions reworded from this thread.
Only 40 amp service? Help?
Stop worrying about what was there and work on getting things compliant with the new code requirements.
You need 2 20 amp countertop small appliance circuits. These can feed the refrigerator and the gas igniter.
Add the range hood or exhaust fan to a lighting circuit.
Old 08-24-2012, 08:26 PM   #4
Sorry about that...The other post was focusing on the panel setup and left off with possibley adding in another subpanel? Thought they are very relative , this post was asking about the wiring to appliance load. One affects the other and this is a DIY so I wanted an electrician to Chime in. I would imagine that your are correct as far as differences of opinion but I would not mind hearing a few
I can't put the kitchen exhaust fans on the lighting circuit, that is seemingly overloaded. Its 15 amp aluminum line and has:
the kitchen lights,
all of the bathroom lights,
shower fan,
the bath outlet, {will eventually be taken out of the equation),
the hall light, and the bedroom outlets.
I was hoping to go over a layout such as...
Assuming all are 20 amps, ut bdo they have to be?
Circuit 1 = Bathroom outlet
Circuit 2 = Fridge outlet and oven
Circuit 3 = Dishwasher and GFI couter outlet #1
Circuit 4 = Exhaust/hood fans, GFI counter outlets 2&3
Or
Circuit 2 = Exhaust/hood fans, GFI counter #3, oven
Circuit 4 = Fridge outlet and GFI counter #2
Any other suggestions?
I guess I'm trying to stay with code, balance the loads, and not bombard the main and have it trip. Not possible since I can not upgrade. I still like the idea of another subpanel I mentioned in the other thread but don't know if it is viable.
An Electrician stopped in today as he was doing work for my neighbor and said it looked like I was doing the right thing on remediating the old problems but was vauge on the new layout as he said it should be find either way. He said I should keep the pushmatic panel and replace them, but that would be a hot swap.
Old 08-24-2012, 08:32 PM   #5
The 20 amp small appliance circuit can only serve receptacles in th kitchen/dining and pantry areas. They cannot feed the DW and exhaust hood.
Please go back and read my last post for the correct circuitry.
Jzone99 (08-24-2012)
Old 08-24-2012, 09:05 PM   #6
Please go back and read my last post for the correct circuitry..................... ......You need 2 20 amp countertop small appliance circuits. These can feed the refrigerator and the gas igniter.
Add the range hood or exhaust fan to a lighting circuit."
Ok, so taking what you saying into consideration does this work?
20-A Circuit 1 = Bathroom outlet 20-A
20-A Circuit 2 = Fridge outlet and GFI Counter #1 (downstream from fridge)
?-A Circuit 3 = Dishwasher alone How many amps???______
20-A Circuit 4 = Gas Oven, & GFI counter outlets 2&3 (future microwave.
15-A Aluminum Circuit (with a lot of stuff already on it) + Exhaust & Hood Fans.
The 1st Exhaust fan is an old wall motor fan, does that draw a lot of continuous amps? Are newer ones more efficient, id think not a motor is a motor.
Old 08-24-2012, 09:07 PM   #7
I'm trying, so please be patient. I don't mind learning. This is a DIY site not a DIBY site. Do it by yourself. Thanks for the replies so far. I am listening to the advice.
Old 08-24-2012, 09:13 PM   #8
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Just curious Greg. You and I usually disagree on D/W and GD on the same circuit. I don't have a problem as long as the circuit is sized for it. Why the change of heart? Please explain.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 08-24-2012, 09:27 PM   #9
Now I am laughing......This is only a 900 Sqft Condo. My wife and I will be going out and looking at houses tomorrow, I won't last on this site. My Wife's Uncle is a certified electrician but lives in another state.
I will try to Skype with him tomorrow so I can show him stuff on the Camera and he can consult me.
Old 08-24-2012, 09:27 PM   #10
Yea, I don't have one. Are they common?
GFCI requirement in Ontario Electrical Safety Code lameon Electrical 15 01-20-2015 06:51 PM
Automatic Closet Lights Sav505 Electrical 52 12-28-2012 07:24 AM
earth ground help cino72 Electrical 33 01-12-2012 02:16 AM
Distance between Heater & Combustibles DIY_JC Building & Construction 7 01-20-2009 07:52 AM
