Confession Time - Electrical - DIY Chatroom Home Improvement Forum
Old 09-24-2012, 11:32 AM   #1
JOATMON
ddawg16's Avatar
Rewards Points: 1,214
Confession Time
I must confess my sins......
Yesterday I was working on the wireing on the side of the house.....all the stucco was pulled off and I was relocating the outside light over about a foot....while I was at it, I was extending the ckt over to the corner so I could install an outlet up high and in the corner to be used for a camera and for xmas lights.
While chasing the wireing...I came across a line that was wire nutted and just shoved up into the rafters........
I did it....12 years ago when I was redoing the kitchen....(at least it was taped). The wire was too short to reach a new light so I took the shortcut.
There...I confessed.....
And I fixed it....since I had the side of the house open, I pulled it all out and ran a new line doing it right. I lucked out in being able to pull part of the new wire through a wall....the new romex is sligtly smaller than the old black tar covered stuff of 60 years ago....so once it pulled through the staple in the wall...it went pretty easy. Which means the new romex is stapled.
On another positive note....I basically rewired everything on that side....the switch box now has a neutral in it...
ddawg16 is online now   Reply With Quote
Old 09-24-2012, 01:48 PM   #2
Julius793's Avatar
Well at least you confessed before the high holidays now you can be forgiven :-)
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 09-24-2012, 02:23 PM   #3
Rewards Points: 610
do you realize all the anguish you have caused!! Now we all feel compelled to "confess" AND FIX...our sins!!!
Of course I don't have any!
techpappy is offline   Reply With Quote
Old 09-24-2012, 07:08 PM   #4
JOATMON
ddawg16's Avatar
Ok....so you are a habitual liar......
Old 09-24-2012, 07:14 PM   #5
raylo32's Avatar
Rewards Points: 1,244
If you still have it open consider also running an ethernet cable to the location where you want the camera. Power Over Ethernet ip cameras are the way to go these days. You don't need no stinkin' power cable....
Live long and prosper.
raylo32 is offline   Reply With Quote
Old 09-24-2012, 07:19 PM   #6
JOATMON
ddawg16's Avatar
Still open.....but....getting the ethernet to that spot will not be easy....the camera I'm using is wireless.....works well...even has audio.....
As soon as the construction is done....I'll be adding a couple of wired cameras in key spots. This paticular spot is more for watching the kids in front of the house.....so wireless is fine.
Problems, GE SunSmart Digital Timer 15312 Mike Muls Electrical 41 07-30-2016 09:13 PM
My first time playing (literally) with mains power Red Squirrel Electrical 16 05-16-2012 03:58 PM
shelves and cure time 7echo Painting 5 04-02-2012 09:27 PM
How do I change the time? MNsawyergp Site Help and Suggestions 4 02-14-2012 07:25 PM
Low budget concrete patio, sections at a time... vertigoelectric Flooring 0 01-29-2012 05:13 PM
